Topic: Mark VII rearend (Read 8648 times) previous topic - next topic
Mark VII rearend
Hello,
  I'm wanting to do a rear disc brake swap into my '87 cougar. I have located a TC rearend from a '88 auto with the 3:73's. However, I am also wanting to do a 5 lug swap. From what I understand the Mark VII rearend and the cougars are the same in length. Is this true? It should be a direct bolt in. What is everyone's thoughts?
Only in America do we use the word "politics" to describe the process so well: "POLI" in latin meaning "many", "TICS" meaning "bloodsucking creatures".
Mark VII rearend
It'll bolt directly on but the Mk VII rear is wider by an inch and a half (3/4" per side)
Mark VII rearend
Okay, now what your saying is the Cougar rearend is 1 1/2 wider than the mustangs and then you say the Mark VII is a 1 1/2 wider than the Cougars? I think i'm going to measure, because I have heard of the Mark VII rearend in mustangs.
Mark VII rearend
NO the Mk7 rear end is 1" overall wider than the TBirds/Cougars....
Mark VII rearend
Then how much wider is an '88 T-Bird rear over a Mustang rear?
Mark VII rearend
Deja Vu anyone?
Mark VII rearend
Quote from: Tbird232ci;137549
Deja Vu anyone?
Yes.....this is the 6th time I've read the exact same questions this week.....
Mark VII rearend
O.K.,I measures the Stang rear,and it looks to be 3/4 of an inch narrower than the T-Bird rear.
Mark VII rearend
Quote from: vinnietbird;137559
What measurment?  Overall, or the housing only?
What Tbird rear?
Mark VII rearend
From  to  on the axle shafts.The other rear (come to think of it) was from an '85 TC.
Mark VII rearend
The '88 may be a tad wider.I have one of those out in the garage as well that I'll measure.
Mark VII rearend
Ok, that seems right.
The  88 rear will have the same measurement from  to  on the axles as well....
Mark VII rearend
Quote from: Chuck W;137536
Ooops. Sorry, my bad. I'm old and my brain sometimes slips into reverse. :hick:
Mark VII rearend
This is by far the single most confusing topic I have ever seen. Somebody should make some kind of graph or chart or something with what is what for every year of all Fox and brake style. Or at least Bird/Cougar, Mustang, and Mark
Mark VII rearend
There seems to be a difference of about (with my measuring) 1 3/4 inches between the Mustang rear and the '88 T-Bird rear.Now,how do I make up the difference when I install the Mustang rear into my '88 T-Bird?1/2 inch spacers and longer lug bolts?
