Topic: T-5 question... (Read 2206 times) previous topic - next topic
T-5 question...
I know the Stang 4cyl T-5s have a lower 1st and 2nd gear, is rthat the case with the T/C T-5s as well? Or do they have the same gearing as the 5.0s?
T-5 question...
I believe it is.  I believe 1st gear is 3.97:1 for the T/C version as opposed to 3.35 for a 5.0 version.
Found a whole big write up here:  http://forums.turbobricks.com/showthread.php?t=3620
T-5 question...
In a nutshell...
'87-93 2.3 T5's and '87-88 Turbo Coupe transmissions are identical. However, the Turbo Coupe T5's have a different speedo gear than the n/a versions (as do all T5's that were behind turbo engines), and Turbo Coupe T5's have an electronic speedo drive, not a cable drive like the Mustangs had.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
T-5 question...
Quote from: Red_LX;137298
In a nutshell...
Clarify that....only the electronic speedo ones do.....
T-5 question...
Well that's why I said '87-88 :p
Garrett H.
Exhaust sound clip
Another clip
T-5 question...
Thanks for the info, guys. I'll get this all sorted out.
