Topic: found nice heads (Read 2037 times) previous topic - next topic
found nice heads
i found heads that have 1.9 intake and 1.6 exhaust valves, will these work with stock pistons using the HO cam?
found nice heads
They should,but you have to check the clearance.Were they shaved?,Your pretty borderline with flat tops.
found nice heads
What kind of heads?  Combustion chamber size?
found nice heads
they are from Arrow head technology i think, its something like that.
um, i cant remember but how small of chambers can i get?
found nice heads
Never heard of that company.....Got any info on them?  I couldn't find anything.....The smallest chamber you can use on a flat-topped 302 AFAIK is the TFS heads.....
found nice heads
i thought stock pistons on a SO motor couldnt use TFS heads?
i thought there valves would hit the pistons...
found nice heads
Nope TFS heads are one of the few heads that work with the flat top pistons the SOs have. TurboCoupe50 uses those heads with a TFS stage 1 cam and flat tops with no problem.
found nice heads
*sigh*
found nice heads
the name is "Aero head"
the chambers are 69cc
130cc intake volume
3 angle valve job
mild head surface
7 degree locks
chromoly Retainers
1.90x1.60 s/s valves
.550" lift springs
all for $399
found nice heads
yep, thats it
found nice heads
I think you should save the $400 and buy either gt-40p irons, or pick-up a set of used alum edelbrocks or tickflow heads.
I bought my edelbrocks used for $700 shipped and they were straight from the machine shop ready to go.
Also look what a 69cc cc is going to give you, under 8-1 compression
http://www.flatlanderracing.com/trwfordsb.html
found nice heads
well, i have the SO motor so i cant have those kinds of heads...
cant i get the chambers milled though?
found nice heads
I think they'd be decent heads on a supercharged engine.
found nice heads
You're looking at the top piston.  The bottom ones labelled "85-87 HO" are more accurate and still on the low side (those have valve reliefs if they are tru HO pistons).....
69cc is a bigger chamber than stock and will lower CR.  Stock HO CR is determined with a 64 cc chamber.
