Topic: 87 TC parts, QA1 Kmember, and more (Read 1052 times) previous topic - next topic
Hey everyone, ive got a few things someone here might find interesting and thought id give everyone a shot before i put the stuff up on ebay.
1. brand new, never installed QA1 79-93 stang kmember w/spring perches. $200 plus shipping
2. 351w 164 tooth flywheel, bead blasted alum. bellhousing, backing plate, clutch fork, and clutch fork boot.  $60obo plus shipping
3. Almost complete abs and ride control system from 87 tc.  all sensors, main wiring harness (not cut up or molested in anyway...does need some new elect. tape on it though), both computers, abs master cylinder, proportioning valve, misc. brakets and hardware.  Pretty much everything you would need except the front and rear shocks, front spindles, and tc rear brake setup.
Make me a reasonable offer, keep in mind the time it took me to remove everything.  I will ship it too
4.  Dual 11inch electric cooling fan out of SHO taurus, nearly a perfect fit on our radiators, would require some customization though.  Both fans have been tested and work.  One fan is missing a plug but you could easly use 2 female spade connectors. $40obo plus shipping
5.  One new matched set of standard bore 5.0l hypo pistons w/ rings (one ring is missing for some reason). federal mogul pn - 273 ap (pistons) and pn - e251x (rings). $80obo plus shipping
6.  2.3l tc  throttle cable. $10obo plus shipping
7.  never used universal mech. tri. gauge cluster (water temp, volts, oil pressure) w/ black faces, black trim rings and braket. $25obo plus shipping
I am located in laurel, maryland 20707.  I would prefer cash and local pick up but will also except paypal or money order if you need something shipped.
I will be checking this post for the rest of this week, but come sunday march 25, i will be posting this stuff up on ebay.
Feel free to email me with any questions (tbird88tbo@hotmail.com).  If you are serious i can send pictures of anything listed.
Thanks everyone!:birdsmily:
[SIGPIC][/SIGPIC]Project Twlight Venom reaching 65% completion.
I found more stuff
8.  stock 87 tc down pipe.  $10 obo, plus shipping
9.  stock 87 tc rad. resivor $10 obo, plus shipping
10.  stock 88 sport coupe cat. converter intacted $40 obo, plus shipping
11. stock 87 tc fuel rail with regulator.  $10 obo, plus shipping
Dont be afraid to make me an offer on anything.  I need more space, and less stuff.  Everything im not using has got to go!
How much for just the abs master cyl,And does it work????
Always good to have a spare one around.
PM sent :D
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
I dont want to brake up the abs and ride control system.  it needs to go as a complete set since its almost all there...ill even throw in the rear shocks and one front shock (only one front because one was deffinitly blown) for the right price, then all you would need for the conversion would be one shock and the front and rear brake parts.
Havent had time to list anything on ebay so everything is still up for grabs.  Probably for at least another week.  Email me with anyrequests.
QA1 Kmember and sho fan assy sold.  Still havent had time to list other stuff on ebay.  Email me with any requests.
