Topic: Sunroof troubles (Read 1382 times) previous topic - next topic
Sunroof troubles
My 88 Bird has a sun/moon roof or whatever the differance is.
This one Flips Up if ya push the button forward and is suppose to slide back into the roof wide open if ya push the button to the rear.
Well a small clip is broken inside and it jams if you try to slide it back, and also the seal is broken and the contac cement I used to fix it about a year ago is giving up.
Can I get a rebuild kit for it or what do you all suggest?
Sunroof troubles
Gasket and adhesive can be bought here. I replaced mine last year with this stuff. Worked good.
http://www.sunroofdoctor.com/
Rick
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
Sunroof troubles
U-Da-Man!!
Thanks Rick
