Topic: 3.8 Headache!!!! (Read 1533 times) previous topic - next topic
3.8 Headache!!!!
:punchballs:  :shoothead    My 3.8 suddenly took ANOTHER  on me! While driving at about35 mph it lost power and started sounding like a Wheel Horse lawn tractor! Then it started back firing through the exhaust. I started the process of elimination with the timing,plugs,wires,& fuel filter. everything was good. Due to lack of funds I'm now forced to try some parts from another T-bird. I have changed the TPS,EGR,Ignition mod.,even the EEC. All with no luck! It now will not run any longer than 15-20 sec. without stalling. If I unplug the single wire connector at the dist. it will idle without stalling, but it shakes & surges violently! Plug it back in, it stalls. I checked the trouble codes & came up with 83 & 14.
3.8 Headache!!!!
Do you have another distributator? The code 14 is a pip sensor code
that could equate to a bad pick-up coil in the distributator.
louie  :birdsmily:
My famous last words:
3.8 Headache!!!!
distributor. I'm another fine example of the Florida school system
louie  :birdsmily:
3.8 Headache!!!!
Yes, I have another distributor. I need to go to the parts store & get another rotor button. It has the screw on type, the one on it has the push on. Thanks alot!
3.8 Headache!!!!
I just finished changing the distributor & it started right up & ran like a charm! Thanks again.:D
3.8 Headache!!!!
The new DISTRIBUTATOR solved Your problem:D :D :D .
Regards.
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
3.8 Headache!!!!
Yes, It was the pick up coil. Thank God I,m a pack rat when it comes to Ford parts!
