Topic: V8 H.o. ? (Read 3563 times) previous topic - next topic
V8 H.o. ?
3 easy questions:
  I have a 3.8. It´s possible the 5.0 H.O swap ?
  It´s better to find all the parts needed or buy the entire donor mustang (or lincoln) ?
  How hard is it this swap ?
  You can do fast answers ,too ...
  It´s only for research.......
(because a topic relates all the technical steps i dont need specifical details)
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: V8 H.o. ?
Just get a lincon mark 7. the have the h.o. and all the parts that you need. however you will want the mustang computer because starting in 88 I think it was all the marks have speed limitors at 106 ot 108 mph.  the lincon one will also be speed density instead of mass air if that matters at all
Re: V8 H.o. ?
Hatstack & SSx;
Keep in mind that Mexcougar has a carb, Duraspark II ignition and no EEC computer in his '85 Cougar.
Re: V8 H.o. ?
Read the cool cats tech section. It details this swap.
Re: V8 H.o. ?
Quote from: softtouch
Hatstack & SSx;
That makes it soooooo much easyer.  With no emissions laws, no cold weather, and cheeper fuel in mexico a carbed 302 is probably perfect.
He will already have the correct fuel lines and ignition system so the 302 would basically just fall into place.
Re: V8 H.o. ?
My question was because here the 302 are plentifull (and even cheaper than a 3.8) and aftermarket parts aren´t hard to find. I guess that with a set of good heads, a new carb, MSD ignition and a cam will get good power (i dont know how much power) but because the reliability problems with my V6 makes me considerate the Avaibility of a V8......
 Of course, here the emission laws are inexistent (only in the D.F and guadalajara are operative but it is not a real problem...)
 Is reliable the V8 ?
 Someone recomends any good Setup for the V8 carb, model year, type, customs parts , etc ?
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: V8 H.o. ?
please don't use a Mark VII, mustangs are much more plentiful, or if you do use the Mark, let me have it when you're done so I can bring it back to life
Re: V8 H.o. ?
Edelbrock sells both intakes and carburetors.  If you decide to get new parts (which I reccomend instead of trying to rebuild a carb the first time around) then get an edelbrock performer intake and either a 500 or 600cfm carb.  I recently bought an Edelbrock 1403, 500cfm electric choke for $269 I think, from Summit.
Re: V8 H.o. ?
Sounds too good, really. If i use a 5.0 i can Use AOD (or better, a T5)?
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: V8 H.o. ?
Yes, you may use either or.  If using an AOD, be sure to get the proper Lokar Kickdown cable kit.
