Topic: Installing After Market Amp (Read 2072 times) previous topic - next topic
hey, so i'm installing an aftermarket amp in a 2dr 94 courgar RX-7, and in the process of running wires i hit a wall .. or rather a back seat, does anyone know how to get this thing out, or if there is a spot i can just run wire threw? in my car i have the half leather half cloth kinda thing going on( not sure if it makes a difference) but yea, if you ahve a solution other than drilling please offer it up :cougarsmily:
There was a spot right around the seat belts are that I fed my power cable thru on my 96.
You will have to remove the base of the seat then feel around where the middle seat belts attach at the floor. You may need a coat hanger. I had an extra set of hands that could grab the wire as I fed it thru.
so, i have to take the base seat of, which i'm assuming is the part that you sit on? and is that just held down with screws or how do i get that outta there?
There are 2 clips that hold it in. You have to push back and pull up. If you run your hand between the seat and the floor it should be right about the middle of the outer two seats.
To put it back in you may need a screw driver or other prying device to put the bar back in the clip.
alright will do, but looks like i'll ahve to wait till tomorow to go any futher due to rain and work:beatyoass: :punchballs:
