Topic: Courgar Speakers / Radio (Read 3363 times) previous topic - next topic
hey guys, so i jsut bought a 1994 merc. courgar rx 7, and iwanted to know if you guys could tell me if 6 1/2" speakers would fit in the front doors, being as i have a goodpair left over from the import i previously owned. and about the radio, is there some sort of special way to get it out, or am i tugging in all the wrong places haha
thanks
bob:bowdown:
edit:
ignore me, you don't have a fox-based car :p
1988 Thunderbird Sport
thank god, i thought i was going to have to go and buy all new 5x7's, and i have the fur screws out, and i can kinda see wheres it's clipped but it still doen't seem to want to come out, so looks liek i have a march break project on my hands
You can make just about any speaker fit in the doors. If you don't want to put in 6x8's just take some thin masonite ande make you a piece to cover the 6x8 hole and cut out the hole in it for your new speaker. As for takeing the radio out you don't need to remove and screws. You need those radio removal tools or and old coat hanger. Take the 2 U shaped pieces and put them into the holes in the front of the radio. Then pull the U shaped pieces away from each other. Then pull the radio stright out. You should be able to have the radio out in just a matter of minutes.
now doesn't that just make me look dumb ... i have no idea where i got these screws from, but i'm putting them back in haha
and for the speakers, where do i get such a thing as masonite, i've never heard of it personaly, and can you get it in canada ?
Sorry I guess I should have explained better. Masontie. That really fine pressed wood. The same thing the back of a clipboard it made out of. Or any really thin flat piece. Even lexan or plexigalss. Thin, flat,Simi-strong that is all you need. If any thing buy some cheap clip boards and just cut off the clip and use the wood. They should have those in Canada. LOL also try the lumber yard. Also the corect speak size for the 94 cougar is 6x8 in the doors and right beihnd the rear arm rest. I just recently got a 94 myself.
ahh haha i get it, thanks i'll try it out after it stops raining :beatyoass:  and i figure out how to get the stupid door panel off, so far every diagram i've seen has done nothing but confuse me, but yea when i get it done i'll put some pics up in case anyone else doesn't feel like using 6x8's(which to me are the dumbest things you could put in a door).;)
To get the  door panel off. 1st pop of the panel with the switches on it,2nd take out the screw right behind the panel you poped off. also take the screw out of the light at the bottom of the door. 3rd then pull up on the panel then pull the top part away from the door. There you have it off. The hard part is gettin it back on there right.
They make speaker adapters that will hold a 6 1/2 and a 1in tweeter. If there is a local car audio place you can ask them or look at Crutchfield.
man thats sick, i didn't even know they made those things, thanks:bowdown:
anyword on removing door panels tho? i'm still havin no luck
its a 94 cougarRX-7
No idea on that I havn't tried to take mine off yet. It may be catching on the interior door handle.
Thanks slamedcat I didn't know that made adapters for these cars. I guess it would make sense seeing how for uses this one off werid size compared to everyone else.
