Topic: These new plug wires suck (Read 1788 times) previous topic - next topic
This may seem like a silly question but I spent $40 on some new spark plug wires and they aren't put together yet.
I have the wires, the boots, and the metal connectors that attach to the wires.
There are 2 different types of boots (both L shaped), 2 different types of metal contacts (L shaped silver one and "straight" gold one), and then my wires. The heavy straight boots are in place on the wires already.
Sorry I don't have pics, can't find my USB cord at the moment.
The wires are Accel superstock. How the heck do I put them together. I have pretty much figured it out but there must be an easier way..
Actually Accel superstock wires do pretty well suck. I used to put them on my old mustang, but stopped using them after the one set I had started arcing around the plug boots after 10K miles or so. Been using Motorcraft wires since then and never had that problem with them.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
I never liked them either.Not the putting them together,that was no problem.They just sucked.I use Ford racing wires.Not much more than the Accel wires,and they're made for the 5.0.Nice function and looks as well.
ACCEL SUCKS!!! Use Taylor or Ford Racing wires.
So I should just trash them? I bought them like 6 months ago and never used them cuz I couldn't figure out how to put them together. Guess I'll chalk it up as a loss and keep moving on.
I've had decent luck with the Taylors, even on my 2.3Ts (which are PICKY about plug wires).  Even when I had to make them for my turbo Ranger.  I'll use Taylors again when I build new ones for the Tbird when I swap from TFI to DIS.
Accel stuff sucks.
Ford Racing/Motorcraft wires can't be beat IMO. Never had a problem with them. Accel on the other hand... whack. Actually I haven't had too much luck with any aftermarket ignition parts. Almost all of them failed in a relatively short period of time.
Accel plugs don't last long...might be good for drag racing...2 runs change the plugs haha...about the sum of it. I used Taylor on my tbird...work good...put 'em on my pickup...still work good:hick: I did have a bad batch of NGK plugs on my pickup...rarely see that with NGK that I'm aware of...just stick with motorcraft...or bosch plat. +4 like I'm putting in my crown vic.
Accel is ok. I never had any major issues using their products. Years ago I made up a set but I believe mine came with 2 flat steel crimpers in the kit. Cut the wire to length needed,put the boots on with some silicone grease, strip about 3/4" of the insulation off  the ends,with out cutting into the core, bend it back along the outside of the plug wire and crimp. Clamp one piece of the crimper in a vise and put the other on top and hit it with a hammer. Plug wire crimping pliers are even easier to use. The different terminals may likely be universal kit which would fit inside  distributor cap terminal  holes(early model vehicles) or snap on to distributor cap tower terminals (later model vehicles)  similar a spark plug. The set of accel solid core wires were probably made up 20 years ago and are still on my friend's car. He still says its never run better. I would try to use them before $hit canning them.
 Needlesstosay, Ford wires are unbelievable in their durability. My '93 Bronco has 185,000 miles on original plug wires. I keep waiting for it to miss and it never does. I believe a set of asf42c or awsf32c spark plugs got 100,000 miles on the same vehicle before I thought they just had to be changed. Again no miss.
 Lastly without going off on a total rant, I think spark plugs, wires and basically the whole secondary ignition system are some of the biggest money making rip offs the aftermarket industry. I probably will get flammed for that and someone will say they do make power but I aint buy'n it any more. I will spend my hard earned cash on something more certain to make horsepower. Just my 2 cents.
 Mike
Accel is ok. I never had any major issues using their products. Years ago I made up a set but I believe mine came with 2 flat steel crimpers in the kit. Cut the wire to length needed, put the boots on with some silicone grease, strip about 3/4" of the insulation off  the ends with out cutting into the core, bend it back along the outside of the plug wire and crimp the terminal. Clamp one piece of the crimper in a vise and put the other on top and hit it with a hammer. Plug wire crimping pliers are even easier to use. The different terminals may likely be universal kit which would fit inside  distributor cap terminal  holes(early model vehicles) or snap on to distributor cap tower terminals (later model vehicles)  similar to a spark plug. The set of accel solid core wires were probably made up 20 years ago and are still on my friend's car. He even says its never run better. I would try to use them before $hit canning them.
 Mike
Ebay the accel wires and pick up some good taylors, the cheap taylors are .
Scott
The most durable and long lasting spark plug wires are the Motorcraft, Ford Racing and Roush Performance ones, all made by Federal Mogul.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
I have Taylor Spiro's on my T/A, and they are a  sturdy wire.  I like them a lot.
