Topic: getting ready for h.o conversion (Read 862 times) previous topic - next topic
I have a Lunati cam part #51099 specs -rrn1-292-510-114 will this work with the so block with e7 heads?
With the SO flat top pistons you will probably have interference with the valves with that much lift. You didn't say what the duration was. Just get a HO cam, those cams can support more hp than a guy would think. Plus, Ive heard that the SO flat tops can't take much more lift than the HO cam has anyways.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
The 510 might be a problem with flat tops.Your pushin the limits.
