Topic: accessory brackets (Read 2550 times) previous topic - next topic
accessory brackets
ive been sitting around thinking about the 5.0 swap again, and running the things i need through my mind, and one was accessory brackets
around here, anything 5.0 related in the junkyard is hard to come by...but on the other hand, there are unlimited amounts of 3.8L mn12's in junkyards
would using these brackets be possible? i couldnt see them being different between a 5.0 and 3.8 mn12, meaning theyd most likely bolt up to a 5.0, but the question arises if they would be clear everything fine, the mn12's and fox's have different engine compartment clearances
Re: accessory brackets
hey if my car goes bye bye i have most of the bracets just not the alt. but is ez to come by round me  so i'll let you have them for cheep bc they will just be  taking up space.
brackets for a 5.0? or a 3.8?
ill definatly keep it in mind, i do like the mn12 bracketry, so id like to use it if possible, but if it wont work, youll hear from me
ok or if my car does come out ok . i can find em around here so. let me know
