Topic: Truck block (Read 1755 times) previous topic - next topic
Truck block
So i was given a free 302 block from a pickup not sure what year, Is there any major differences I should be aware of.  The plan is to rebuild another engine outside the car so that I can just swap it in rather than have the car sitting without an engine during the rebuilding process. Oh and the "rebuild" includes a HO conversion mwahahaha.
P.S.  I havent seen it yet so I don't have a casting number or anything.
2004 Impala
Truck block
Come on guys I need a little help here
2004 Impala
Truck block
were gonna need some kind of number to tell you what the diffrence is. Assuming its a fuelie, the intake will be flipped around the wrong way, so will the fuel rail's. Just like that crown vic's, and obviously the trucks. Other then that, were gonna need to know what year it is.
Truck block
All I will be using from the truck is the block itself.
2004 Impala
Truck block
No differance. other then if it is pre 86 it will be a flattappet camshaft and a 2 peice rear main seal (pre83)
Truck block
The truck 5.0 was a non-roller cam until '94 when they finally went to a Mass Air setup.  The blocks ARE machined so that you can swap in i roller cam setup from '86 on.  The cam profile on the bank fire Multi port injection (86-93) has identical lift to the SO cam as well as the 1-5-4 style firing order.  I have never found duration #'s for the cam and I can only assume they have more duration than the SO cam due to the fact that the trucks came with 19 pound injectors as opposed to 14's.
Truck block
Sorry for the highjack,
 Are there any piston differences?
Mike
Truck block
Thats what i thought so as long as i'm just using the block i can do it.
2004 Impala
Truck block
Quote from: TurboCoupe50
Dunno if if they are forged but they definatly have valve relifs...
basic rule
All 5.0s with E7 heads have valve relifs... 5.0s with E6 heads got the flattops, which include the '86 Stang & LSC HO. Also the '87 LSC HO used the flattops as they still had the 200hp 5.0...
This quote comes from here:  http://www.foxtbirdcougarforums.com/showthread.php?t=10109&highlight=truck+block
