Topic: 460 dyno run (Read 911 times) previous topic - next topic
460 dyno run
Notice any thing wrong ?!
Not much HP.. but alot of TRQ
460 dyno run
Looks alittler lean on the upper RPM range.
  Should be at a MIN 13.0 AFR  more power around 12.0 for NA
460 dyno run
that's uhh..backwards there....11 is full rich at 4K rpm !!
460 dyno run
Whop. i'm sorry, i see what you mean,
i'm not sure why it goes back to leaning out after 4k
the whole setups a little wierd, kinda funny, he tryed a 3rd gear "drive" pull, crusing at about 40, and nailed it, the truck shifter back into first gear and just roared, this thing sounds MEAN !!
