Topic: 2005 car plans (Read 6298 times) previous topic - next topic
2005 car plans
what does everyone have planned for '05?
-11" front brakes
-Rear disc brakes
-edlebrock heads
-suspension upgrade/replacement
Re: 2005 car plans
Paint job
11" brakes
HO conversion
the paint job is at the top of the list though...
Re: 2005 car plans
Bracket Race
Bracket Race
Bracket Race
Maybe the 406 next winter
OH Yea... did I mention bracket race??
Re: 2005 car plans
-Put my headers, h pipe, and lers on
 -Maybe a new intake?
 -Replace almost all of the rotted rubber bushings throughout my car
Re: 2005 car plans
Paint job
better system
interior restoration
dual exhaust, glass pack lers, high flow cats, out the side.
Re: 2005 car plans
* twin turbos
* 42lb fuel injectors
* pro m mass air meter
* new control arms (uppers/lowers with spherical bearings)
* Trak-Lok rebuild
* New auto meter dash hopfully
* fiberglass center counsel
That should keep me busy for awhile huh?
Re: 2005 car plans
>>Convert back to 4-lug
>>Paint Turbines Black
>>put engine back together [new intake, carb, ignition, rewire]
>>put trans back together [new torque convertor, shift kit, cooler]
>>MarkVII 73mm calipers.
>>new rear... hopefully TC.
>>sell stuff
>>buy an Eagle Talon TSi AWD
>>have fun. ^_^
Re: 2005 car plans
full h.o. conversion maybe a couple of performance up grades like bigger throttle bodies and such. I want to go with an after market cam as well.  alot of touch ups like paint and things
Re: 2005 car plans
11' brakes
5 lug
mustang diff
paint job
stealth intake
cam
D0OE heads ported polished
Carburator
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Re: 2005 car plans
Which car?  I have 6.......
The biggest is probably the turbo Bird is getting painted....next month most likely.  Also, I have a MegaSquirt ECU I need to get assembled and in there as well....
Re: 2005 car plans
Edelbrock 500cfm carb
Old '83 Stock Stang 4-bbl intake for the above - Maybe upgrade to Edel. Intake also.
Duraspark ignition, also for the above
8.8 3.73:1 Trac-Lok rear (started pulling it out today)
New bushings for suspension, possibly coils
Re: 2005 car plans
All new (and bigger) wheel and tire combo
External fuel pump to feed the monster underhood
MM Caster/Camber Plates
MM Rear Lower Control Arms
Fiddle with the tune some more and get it strapped on a dyno
Re: 2005 car plans
not sold on the CHEs HAWK?..... :dunno:
~John~
Re: 2005 car plans
1985 Cougar:
5.0L HO Conversion with GT40 intakes
BBK 1 5/8" Headers
2 1/2" Offroad H-pipe, and flowmasters
T5 swap
5 lug conversion with Bullit rims
4.10:1 gears
Twin turbos
weld in the subframe connectors
bolt in strut tower bar
install adjustable clutch cable and quadrant.
Full restoration: interior/exterior/underneath/engine bay
Paint the car.
I have all the drivetrain/chassis stuff, just have to swap it in now.
