Topic: Anyone have a warm-air intake malfunctioning? (Read 931 times) previous topic - next topic
I've had mine connected and disconnected since I've owned the car.  A few days ago I reconnected it again.  It seemed to help on cold wet mornings but performance feels off.  And I've just been back from a drive, nearly an hour, albeit I made a stop.  In any case the engine was nice and warmed up but when I got back home I checked and the intake flap was still open.  I'm ready to disconnect it yet again but any thoughts?
You talking about the one in the snout on the air cleaner?  Umm, should be open with the engine warm, closed when cold.  If it's closed with the engine warm something's not connected right.  Vac line should come off the Tee to the bimetal control valve on top of the cleaner, then from that over to the vac motor for the vane.  Now, what I found on my '86, was if the lines are connected backward on the bi-metal vac switch, it won't open.  If it don't open, no wonder the performance is off.  It's smothering the engine.  Note the size of the heat pickup tube from the "stove" to the snout.  Not even half the cross-sectional area of the snout.  Fortunately, I live in the south, and heat pickup isn't necessary.  The rubber coated cloth tube with the spring in it kinda came unsprung after 21 years of service.  I've thought about just taking the vac motor and flap outta the snout and capping the connection on the tee.
:birdsmily:
Mine is al SEFI,but it LOOOOOVES cold air.
Quote from: Old_Paint;130846
The air intake warmer only responds to air inlet temperature, not engine temperature. The bi-metallic strip tries to keep the incoming air at 70-90 degrees. If you engine is warm, but it is 20 degrees out, the valve  may be fully closed (to cold air).
