Topic: valve covers take off (Read 1521 times) previous topic - next topic
if i take off my valve covers, can i expect to have oil spill out all of my engine?
Not if the engine is cool (hasn't been run for a little while).Just have a rag handy for a drop or two,but it's not a messy job.Use rubber coated steel gaskets,not the cork ones.
ok thank you. i just bought a pair of cobra valve covers from ford racing. they look pretty cool. i'll take a pic once they are in the car
I want a pair of those myself.I have to wait until my new heads are finished at the machine shop,though.There's a G I A N T swapmeet this Saturday my friend and I are going to.I hope to find a pair there.I have to watch the budget since paint,tail pipes,and window tint are on the "to do" list.
I had a few small drops but I did mine in the cold.
Use the gaskets Vinnie suggests.  I did the same thing awhile back.  You may also need a intake spacer for possible clearance issues.  I installed one while things were apart.  I did not try without it but it looks like there could be clearance issues if it is not used.
I have the Cobra manifold and the Cobra valve covers with no spacer. The throttle body linkage bracket touches the valve cover a bit but really isn't an issue.
Quote from: quicksilver;130493
There wont be any oil run out if it is cold
It's tight.If it's to tight ,skip the gaskets,Use thin black silicone.
Retourqe want's in awhile.shiznit I have old 70's aluminum covers.
Wont fit my rig.With a spacer they will fit.
No they won't the 1-7's .mess them up,For sale maybe?
