Topic: temp question (Read 1075 times) previous topic - next topic
temp question
Some of you guys may remember that I had an issue with my car getting warmer than I felt it should.  Finaly this weekend I put in an actual temp gauge so that I can get the exact temp.  It generally runs from 195 to 215 at the highest.
Is this acceptable?  I think it is but want to make sure.  What is the max for this car?  Also relatively where on the temp gauge should my needle be compared to one with degrees on it.
Thanks guys.
tc
1986 Mercury Cougar -- Midnight Wine and Taupe  ($1700) in 1999 w/ 103,000 miles.  Now with a motor from an 87 with 54K on it.
1988 Mercury Cougar -- Light Sandlewood Metalic  ($40)  in 2003 with 111,000 miles.  Needs a fender, some welding and a good tune up.  Possibly my next daily if i ever get it to the shop.
1991 GMC Sonoma, My $50 daily driver.
temp question
Sounds normal to me.
My '84 shop manual says The thermostat should start to open between 193 and 200 and be fully open at 221.
249+ is overheating.
temp question
That's what I thought but wanted to make for certain.  Any Idea's why my stock temp gauge would read it wrong then?  It has a new sender.  The gauge worked before I switched engines.
Also I noticed today that it will go up to 225 swing all the way back to 160-180, back to 210-215 and back down to 180 and eventually even itself out.  Anyone ever see this condition?
tc
