Topic: Dead short (Read 1519 times) previous topic - next topic
Dead short
I have a dead short in my 1986 mercury cougar XR-7 2.3 pulled fuses and many relays and still there. The battery drains in about 3 days help please.
Dead short
I would call that a slow drain.
What kind of tools do you have for trouble shooting electrical problems?
Dead short
Quote from: softtouch;129200
geeetterrr done:D
Dead short
what will i need i have a good amp meter. and a light.
Dead short
Is your Amp meter part of a multi-meter that also has voltage and resistance testing functions?
I will assume, correct me if I am wrong, the car sits for three days without being driven. Sitting for three days with the fuses out, the battery drains.
Do you have a battery charger?
Is the car stock, electrically speaking?
With the battery charged disconnect the negative battery cable.
Hook your test light between the negative battery terminal and the battery cable. Does it light at all, even dimmly?
If the light lights, take all the wires off the starter solenoid terminal that the positive battery cable goes to.
If the light goes out, put the battery cable back on.
Light still out?
Touch the other wires one at time to the solenoid terminal to find which one lights the light.
Let us know what you find.
Dead short
this one might be worth investing in a good multimeter for. i'd disconnect the negative and hook up the meter in amps inline with between the battery and the cable, make sure all accessories are off, measure your amp draw, and pull fuses one at a time until you find the circuit you're working with, then find what all is on that circuit, and then go from there. (i just re-read the post. well, get a good digital multimeter if ya ain't got one already. and, uh, if you pulled all the fuses already and it's still there, look at the schematics before the fuse block.)
Dead short
ok guys will try it all. thanks so much for your input. very much appreciated.
Dead short
One thing to make absolutely sure of when trying the ammeter method is that the dome light, hood light, glove box light, center console light, and trunk light must all be off.
Also, try unplugging the alternator. A bad diode inside the alt will cause it to act like a motor instead of a generator. Since the "motor" won't be powerful enough to turn the engine, it'll just sit there and draw current.
Dead short
The test light is the safer option if it works for you.
If while using the ammeter, you ground out the positive battery voltage while messing with the wires, you can draw more current than the meter can handle.
You may damage the meter or blow its fuse if it has one.
Also there is a normal drain from the EEC keep-alive memory and the clock. I think this is less than 100 milliamps.
If these test indicate no drain, leave the battery disconnected for three days and see if the battery can hold a charge. If not it's new battery time.
