Topic: Carbed AOD Help!!! (Read 2826 times) previous topic - next topic
Carbed AOD Help!!!
Ok, This was breifly covered in the Fila thread, but how do I convert an Edelbrock to work with the AOD. It still has the rod on it. Would it be eaiser to go to a throttle cable? I know I can fab a bracket for it to work but I need more direction. Anyone do this / have a pic?
Carbed AOD Help!!!
Anyone at all?
Carbed AOD Help!!!
Your car does not have a "kickdown".
Carbed AOD Help!!!
Ok, TV Rod or what ever the thing is, how can I get it to work with the carb? Can you offer any more wisdom Claude?
Carbed AOD Help!!!
Look in Summit or Jeggs.Lokar makes a TV cable for the carb and AOD.I THINK it's under $50.00,and it's worth every cent.
Carbed AOD Help!!!
You would think the kid would have a Jegs book.. I have dozens of them and the Ford TV adapter is in every issue.
Carbed AOD Help!!!
Fila,if you don't have their catalogs,just find them online and order one.They'll put you on their mailing list for free.TONS of parts in either one.
Carbed AOD Help!!!
I had the summit, a year one stang book, and a few stang' catalogs, not a jeggs. I just don't know what to order. In suppit they have 2 vabled. Both for AOD's. And Scott made some mention of being able to fab a bracket from the carb to the TV rod. Which would be better, spend the $50 odd on the kit or try to fab it for less?
Carbed AOD Help!!!
Quote from: 88turbo;129260
depends on what you want something fabbed that could fail or something made to do the job...
that doesnt make a lick of sense,,,
thats like saying, since i built my deck instead of paying someone else to fab it up,, it will fail.
Carbed AOD Help!!!
Scott, your the one that told me to fab something. Can you even use paint to give me a clue of what to do? I know how it shorks and how it connected to the CFI but it's not even close on the carb. I though ti would just have to ut a stud on the carb and put the TV roc and a return spring. I know this is more then likely wrong but thats why i'm asking for help.
Carbed AOD Help!!!
When I switched to the 4 barrel Edlebrock that I have on the car now, I had to use this EDL-1483. Its an adapter for the TV rod it was about $20 at Summit. I then had to make slight adjustments at the transmission so it would kick into passing gear at the appropriate time.
Carbed AOD Help!!!
Thanks Kyle, thats the Info I needed. Did you change anyting else or change anything else?
Carbed AOD Help!!!
Quote from: 84 Fila;129270
I just thought of something else,, instead of two holes,,, just make sure one end is big enough to hold the plastic bushing form the tv rod,, then make the other end slotted so it is adjustable.  that would make it possible for you to do all the tweeking up at the engine bay.  If you break the bushing, they are sitll avail at ford very cheap.
i have no idea what the actual out of the box parts look like but ill imagie they achieve the same concept.
