Topic: digital dash ? (Read 2173 times) previous topic - next topic
digital dash ?
hello members on my 87 t bird sport the right side of the  cluster is looking faint .i can hardly see the  guage as to where it has the dte and other  listings .on the left and centre everything else is fine any help would be greatly appreciated.    twister
the movie twister i lived it big cabin oklahoma 1973 man that was some scary shait!!!!
digital dash ?
You probably have a bulb out at the right of Your cluster, this need to remove the cluster and change the faulty bulb...
When I swapped to a base digit cluster to a full digit cluster last winter, I changed ALL the bulbs for a LED white bulbs, it's a bit more expensive, but You never change this again...
Regards,
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
digital dash ?
thanks dom  would one  bulb cause this  or several  and are there more than one bullb behind thanks
dave
digital dash ?
There are several bulbs, you may as well check them all when you pull the cluster
V6->V8HO 88 LS
5.0L V8 87 XR7
digital dash ?
i gota step by step in my diy link above my sig if you need instructions.
digital dash ?
Quote from: twister;128948
dave
I don't remember if he have ONE or TWO bulbs per side, I guess two, same for the speedometer, Before I change for a full digit cluster, My base cluster was a one bulb burned, and never guessed since I remove the cluster to swap...
Check all of Your bulbs when the cluster removed, and pay attention if You have the prnd21 in dash to don't broke the little wire between the column and the cluster...
Again, I suggest strongly to put a white led bulbs in Your cluster, it's a bit more expensive, but You'll never change...
My Bird have all leds lighted, interior and exterior (tails, markers, ect) except the dome and under the dash lights...
Dom.
digital dash ?
The bulbs more than likely are all the same age, for a cheap as they are I would just change them all while you have it apart. Not that it is that involved but I would be aggravated if I changed only one and then a week later another went out, thats just the luck I have.
digital dash ?
The two bulbs for the base digital cluster read-out are halogen bulbs.  DO NOT touch the glass on those with your fingers before you install them, otherwise, you'll be back in there again long before you wanted to be.  The rest of them are standard incandescant bulbs.
TBirdManiac, can you give us manufacturer/model numbers on the bulbs you used?  Like you said, maybe a little more expensive, but you NEVER have to replace them again.
:birdsmily:
digital dash ?
Quote from: Old_Paint;132952
Hello,
I purchased a bunch of these on ebay, some are single leds (perfect for dash, ect) and some multi leds, perfect for side markers, ect...
Check on ebay, it's cheap...
Dom.
