Topic: Engine swapping (Read 1099 times) previous topic - next topic
Engine swapping
Thanks for that info i do have the original 5.0 fuel injected engine but it is blown and have been offered a carbuerated engine and was also wondering if i would have everything on my engine to convert the other one to be fuel injected?
Engine swapping
Computer, Fuel Rail, Upper and lower intake, injectors, complete wire harness, 40+ psi fuel pressure, IAC, TB...
I think I got most of it.
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
Engine swapping
On the off chance, do you mean SEFI or CFI? IF it's CFI you need a 2 barrel intake, the CFI itself, computer and harness.
engine swapping
Engine swapping
so your 87 5.0 has blown,, and your gonna use a donor carb engine.
what is the casting number on the engine,,?
i would only use the short block and keep your good heads unless the one your getting its better.
consider the differences in your cam as well being roller now, swapping to non roller.
Engine swapping
If you use your accessories,you'll need to swap the water pump,and the timing cover.I had a carbed engine that I put my EFI on,and had a serious idle problem due to the cam.Also,the harmoic balancer was different.If you can find a roller engine,use it.If you're not going to H.O power right now,grab one from a Crown Vic or something.
