Topic: 3.8 vibration (Read 2914 times) previous topic - next topic
3.8 vibration
Hey guys everytime im in a stop light with the brake pedal on the floor the car starts to hesitate but when I start moving is ok what can it be, I changed spark plugs, cables etc :america:  :repost:  :sawzall:
Re: 3.8 vibration
Maybe the torque converter is staying locked?
Re: 3.8 vibration
Is not the torque converter because my tranny and converter are 8 months old and this vibration has been there before i changed the tranny
Re: 3.8 vibration
its the engine struggling to make power
Re: 3.8 vibration
no the engine works ok when im moving it only exhitates when im in a stop light with the brake pedal , if i have the brake pedal on and hit the gas pedal a little it stops
 :america:  :sawzall:
Re: 3.8 vibration
Does it stop vibrating if you just take your foot off the brake?
It could be a vacuum leak in the power brake booster.
Re: 3.8 vibration
when i took the brake pedal off is not so bad but have to press the gas pedal a little so it stops the vibration
Re: 3.8 vibration
What year is the car?.  Idle RPM too low, TPS, IAC.....
Re: 3.8 vibration
Mine does the same thing. And when in gear and holding the brake it idles about 500 rpms. If I bump it up to 900-1000 rpms it stops and doesn't shake anymore.
