Topic: How should I fix this?? (Read 1300 times) previous topic - next topic
Here is the only real damage to my cat.
How would I go about fixing these?
I also have a small dent in the roof. No picture of it though
Thanks
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
What part of the body are we looking at?
It would be a LOT easier to just grab another fender and install it.It wouldn't take more than half an hour if you take your time.
The first looks like driver side lower fender and the other looks like pass side rear quarter just below the fuel door.
Long live the 4-eyes!  - '83 Tbird Turbo - '85 Marquis LTS - '86 LTD Wagon
Quote from: Slinky;127033
The bottom picture is right next to the gas cap on the passenger side.
1992 Ranger 4.0
2019 Ram Rebel
My Sport has a dent right below the belt line on the passenger side rear.I'm working on it.I'm undecided if I'll keep at it,or have that piece of the fender replaced on the rear.For the front,just swap it.
Don't change any parts for these littles damages, it's easyly repairable with a body hammer and dolly block, it's not a very rusted parts, (the 1st pic), Just hamming to get some decent surgaces, grind all paint with a 24 or 36 grit disk, pre-finish with some plastic body filler (bondo), rope Your plastic as best looking as possible, sand with 60~80 grit, prime it, and apply one layer of finishing putty, sand with a 180grit and 320, re-prime it, check the surface, and reapply another layer if needed, , then prime 2-3 layers after that, with a 320 and 400 grit for the last layer, and paint it!!!...
Regards,
Dom.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
If you're going to repair the front fender, I'd do what Dom said but I'd also use VERY little heat to help put the metal back into shape. Hammer/dolly; very little heat on the creases-hammer/dolly on heated spots-dab with cool cloth. Repeat until sheet metal is almost smooth then follow Tbirdmaniac's proceedure. Yes, it's more work but I agree w/ Dom, It's repairable.
John
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
that rear qtr trim would probably yield the missing bolt inside the trunk well forward and way down to the right.  that trim comes with bolts molded into the plastic and if you find the part, just fix it with 2part epoxy.  you'll see the rest of the nuts you need to remove along the interior of the trunk pass rear qtr.
on the front fender,, you'd be surprised how easy the fender is to come off.  Its really cake.
bolt locations........
vertical line of bolts along header and bumper cover
wheel well skirt phillups screws
one on the bottom directly behind front driver wheel
a few along the engine bay and one hiding up near the windshield
one directly in line with upper door hinge visible wth door open
from the looks, i would think it would be best to "fix" the fender off the car cause thats a funky crease and its at a point where there is a factory bend in the sheet metal.  I wouldnt put heat on these thin ass bodies,, thats what bondo is for if you dont get it perfect.
The rear quarter trim is straight, the fender is bent in a little. py picture I know sorry.
I am reading up on the subject, so hopefully I can fix it this summer
1992 Ranger 4.0
2019 Ram Rebel
