Topic: How to take pictures of engine parts (Read 4351 times) previous topic - next topic
I noticed this a lot, lately, and the EGR thread reminded me that there is an easy solution to these blurry images of rusted metal and thumbs.
To fix this problem, press the 'macro' button on your camera for close shots (and it has one, trust me). It's the one that looks like a flower.
There are some other obvious tricks, like make sure you have something other than a flash for lighting (heavily contrasted shadows are confusing), and be sure that lamp/trouble light/headlight is behind the camera, not the part.
This may sound nit-picky, but with a clear image to work with, the fox geniuses on this site will be able to help you a lot easier. Take it from someone who once posted cell phone photos of his cracked turbo for advice. ;)
AND,not only will the Fox geniuses be able to help,some of the Fox idiots can too.LOL.
Good thread oldraven :thumbs:
Since I am indirectly responsible for the creation of this thread, let me say I currently own a Kodak Easyshare CX7300.
This Camera DOES NOT have a Marco Function!!!
Thankyou Very Much.
-DMC24guy
[/SIZE]
I don't believe my HP (which is a few years old) has a macro function either. I'll have to look tonight.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
O.k. I'll rephrase that. Unless you're DMC24guy, you have a macro button. ;) Seriously, I've never seen a digital camera without a macro function, barring cell phone cams.
Red LX, just plug your DC model number in the search function of http://www.dpreview.com and you should be able to find out if it has a macro setting.
Actually my Apex camera doesn't have a macro mode either, its sort of a low end one though (although it does pretty well and it's 3.2MP)  One of these days I'll suck it up and spring for a decent camera.
My Kodak EasyShare CX7430 has a mode select thumb wheel on the top.
They call it close-up mode and it is the flower logo on the thumb wheel.
Mine has one but I never knew what it was for so I never used it. Not to sound dumb, but what is a macro function?
My favorite 50mm lens has no macro mode, does that count? ;)
17-70mm f/2.8-4.5 one can get as close as ~3 inches though.
Quote from: blueovalford;127085
It makes it so your lens can focus in on things close up.
Most cheap lenses (standard cameras) have a 1:2 or 1:3 "macro"/close up mode. Say if your lens has a 50mm macro mode with a 1:2 ratio. Your lens would be able to focus on something 100mm (~4 inches) away from your camera, through maybe 1.5ft, before things begin to blur. True "macro" mode is 1:1. There's other numbers that go into the equation, but this is enough to understand generally how it works. You lose picture quality with such modes (most people don't pay that close of attention), but everything can be focused upon much better than the typical 2-3ft minimum distance for an entry level lens.
Hope this is simple enough of an explanation to get the general idea across. Digital cameras really throw off raw numbers in explanations as there's different sensor sizes which change the mm ratings on lenses.
1988 Thunderbird Sport
my camera is a FUJIFILM A201 model made several years ago.
i never knew what the flower was for,, i just found it.
BTW,, this is one helava camera, it just sucks up the double A batteries too quickly.
Quote from: jcassity;127126
They made some great digital cameras when the things were new. I still have a 2800Z that takes beautiful pictures. I'm not sure, but I'm willing to bet they used the same imaging sensor. Unless you need to print something larger than 4x6's, that camera will take pictures just as nice as the latest 10MP point and shoots. Recommend keeping it ;)
Mine sucks FOUR AA's at a time. Alkalines lasted around 20-30 shots, 1800mah NIMH's about one 128MB card full (166)
I still have my Vivitar f3.5-4.5 28-85mm Macro for my XG-9, but that body is leaking light like swiss cheese. I only use my 18-55mm 1:3.5-5.0 EF-S that came with the Rebel. It's a shame, because I have a few nice lenses for the Minolta that are just sitting there now. I should just give them to my sister, who has my old XG-1 that works perfect still. (I gave that to her with a 1:50 fixed when I got the XG-9 and its gear)
I have an HP Photomart 720 digital camera 3.18 mega pixel that has been very good to me except that it doesn't have a macro mode.
To compensate, I take the picture at the highest resolution, then with the basic photo editing software that came with the camera, I zoom in and crop the image. It's a little more work but the results are about the same.
Brent
One of 1,246 built
You guys should be using lithium batteries for yo cameras.  They last FOREVER.  I took around 5 hours worth of video on my Nikon L6 and still had enough battery to take ~200 pics before replacing.
