Topic: got the k-member swapped in today (Read 3839 times) previous topic - next topic
it's an AJE piece made for a fox with a 4.6L. ;)
it fit pretty well, but i for some reason the steering shaft hole wouldnt line up with the hole on the column. so i drilled another hole. :beatyoass:
1979 Ford Fairmont
[/B]
Looking to move up the Top25 list? What 4.6 is going in? An 03-04 Cobra swap would be really nice.
Jim
Quote from: thundr306;126738
Jim
WHAA??? im #1 with my uber quick 13.5 LOL!
no '03/04 cobra motor. 95 teksid block, 01 cobra heads and cams, cast mark viii crank, mach 1 pistons and rods, sullivan intake, MSD mod controller, 150 shot, and a 750 double pumper. :tg:
1979 Ford Fairmont
[/B]
Yea, I realized that after I wrote it. LOL
Sounds killer. Are you going to use the MSD ignition controller?
Quote from: thundr306;126748
yessir
1979 Ford Fairmont
[/B]
Carbed, huh? That will be interesting, I've never seen a 4.6 with a carb on top. Is that Sullivan intake a custom piece or is it mass produced? You don't have any engine pics right now do you?
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
this is where im getting the intake:  http://www.sullivanperformance.com
here is a pic of my motor right now:
1979 Ford Fairmont
[/B]
Cool !!!! My buddy is going to put a 96 Cobra motor in his 88 "mustang". How much does one of those cost,Part #. If people keep building stuff like this It will be hard for me to keep up.
 Oh well we are the top three as of now. And keep up the good work.
1999 Trailblazer(wifes rig)
That would greatly simplify my DOHC swap  :grinno: Are you going to get the hydro boost setup or are you going with manual brakes?? Lets compare notes :D
I just went to the MSD website.......HOT D@#@@M!! Here we go carbin  :shakeass:  Thanks for the tip on the controller
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Pretty cool stuff. I had thought about a modular motor in my 460 TC so I could run the Modular class at mustang events. They pay out really well now. I'll be watching your progress. :birdsmily:
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
i got the k-member and bolt-on spring perches for $375 shipped through a local AJE dealer. i have about 80% of a complete hydro boost system, but debating on using manual brakes instead.
if all goes as plans(and funds are there), i should have it together no later than this summer.
1979 Ford Fairmont
[/B]
cool. why the mach 1 pistons and rods though? if you are going through the hassle of swapping them then id buck up and get some decent peices instead of powder metal ones. they are basicly the same as the mark vii and na cobra ones.
if the car is street driven id realy wouldnt even consider manual brakes. most guys that do end up switching to hydroboost later on and its alot harder at that point.
i wish i didnt bail on mine but its gonna be sweet seeing some of these done finally. i was 99% ready for assembly.
nice price on the k member & purches as well. id consider having them welded eventually. i was going to anyway. i was going to powdercaot mine sourapple green lol.
~John~
Awesome work !!! I plan on going with a 351W late this year or early next year.Your kind of work insopires me to get my pieces together and get building.
5ohbird, I just got off the phone with MSD Tech. Are you going to switch to a C.O.P. setup?? I guess I'll be doing that swap in order to run that Ignition controller. I downloaded their info and diagram for it and it's rather cool.  Just thought I'd ask.
John
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
told my dad about 5 months ago im going to swap a 4.6 4v in a fox Bird or Cat one day.... sprayed and blown
nice work cant wait to see it done
