Topic: EEC swap questions (Read 1652 times) previous topic - next topic
EEC swap questions
Hey guys. I've got a computer supposedly from a 93 tbird I'm using for an HO swap into my 87 cougar with an SO 5.0 . Its part no. is F3MF-12A650-AA and the program code is S3S. I'm having a hard time finding info about this EEC computer on the web. I know I'll have to get the accompanying MAF sensor and wiring harness adaptor but is it useable with my current SO wiring harness. By the way, I'm going to be running a '93 aod behind a '93 HO motor. Any help would be appreciated even if its just steering me in the right direction. Thanks
EEC swap questions
I forgot to mention that I'm going from speed density to Mass air, although you probably knew that!
EEC swap questions
Should be just fine,the connector will be exactly the same,however you will have to move some pins around.
Look in the tech section about doing the maf conversion for your wiring harness.
EEC swap questions
Thanks Dominator. I've seen articles on the MAF conversion but was concerned about any changes made during the change to the MN12 platform. I can sleep a little better now.
