Topic: what spacers do I need to mount 17x9s? (Read 2272 times) previous topic - next topic
Hello, I wish to mount 17x9s to an 86 Cougar 5.0 and plan to use 245/55 tires.  What size spacers will I need and do I need new lugs? Can anyone recommend a vendor for the spacers?  Thanks.
Everything depends on the backspacing of your wheels and your brake setup.
1984 Thunderbird V8
detail
Here's some detail on the wheels:  (17x9" 2006 2007SHELBY COBRA / GT-500 style GT500 chrome aluminum wheels, in Ford's 4x4.25" lug pattern, +18mm offset).  Everything on the Cougar is stock.  Does that help?
Subscribing........
  I'm wanting to buy a set of 17x9 wheels (Cobra R) and they come with 255/40R17's.I hope they work.What do you think?The wheels are made for the Fox mustang.
Quote from: vinnietbird;126450
Then they will work just fine.  Fit will be just about the same.
1984 Thunderbird V8
Awesome.I'm ordering them,and not lookin' back !!! LOL.
Quote from: shaggy;126410
I don't know about 245/55 I would go with something with less sidewall like a 245/45. Maybe wider in the back. Those GT500 wheels will look awsome I bet. Does anyone have a picture with these on a fox T-bird?
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
I got some cheap spacers from JCWhitney that are 1/8" thick and I have two on each front wheel. I wish I could have avoided using that much spacer, hopefully the TC spindles will help somehow.
These are the wheels I have:
http://cgi.ebay.com/ebaymotors/17-Mustang-Cobra-R-Wheels-Rims-255-ZR-Tires-79-93_W0QQcmdZViewItemQQcategoryZ66483QQihZ019QQitemZ290075815457QQtcZphoto
Did you have to install longer lug bolts?
Quote from: 86elan;126528
Thanks everyone for the feedback.  Is the 245/45 a personnal preferance or do you think there might be clearance issues with the 245/55?
The wheels I'm buying come with 255/45R17 tires already mounted and balanced.$888.00 to the door.Not bad.
Here they are on a Cougar (like this guy has).  Probably pretty similar on a Tbird.  ;)
1984 Thunderbird V8
Nice wheels.I just saw a set for 4 lug cars on E-bay.By the way,steering limiters are at Ford,part # N804842-S.$3.84 each.
Quote from: vinnietbird;126545
No, I was afraid I might have to, but nope.
Quote from: shaggy;126579
I'm not sure but a 55 might be close to the fender lip on the front, the 255/40s on mine at stock ride height could likely hit if there was a big enough bump in the road. The rear shouldn't be a problem.
This is just from Jeg's
BFG G-force T/A:
245/45R17  25.7" diameter
255/45R17  26.1"
255/50R17  27.1"
275/40R17  25.7"
spoogeho Ecsta SPT:
255/40R17  25.0" diameter
