Topic: What do you guys gap your plugs at for 5.0? (Read 1033 times) previous topic - next topic
Just wondering because my car is still plagued with a rough idle.  I don't know from experience what an engine missing sounds like but if I had to describe what I'm hearing, missing sounds pretty good for it.  My plugs are all gapped at .050 and my ignition has a 50,000 volt coil...should I be having that sort of problem?
42-48 i believe... just pullin numbers off the top of my head..
the sticker on your fan shroud says it all,, .050 is fine.
take a spray bottle of water out to your car at night, start er up then spray water over wiring and plug wires.  when you see sparks jump , investigate there.
get a can of carb cleaner and spray it along yoru vac lines and listen to the idle change.  when it does, investigate there for a broke or cracked line.
these just a couple of many checks,,,
in my DIY link,, check
tps voltage and adjust it
egr for carbon buildup preventing it from closing all the way or a ruptured diaphram
spark jumping with a spray bottle of water
vac lines for cracks using carb cleaner
compression test
fuel presure **********UNDER A STINKING driving LOAD******************  not just at idle
skim through and check other things like are there tiny metal shavings down in the pick up magnet deep in the dizzy?
all this wont take all that much time, might as well write down your findings in a journal or something.  helps you troubleshoot later on by comparing history data.
if you cant find any spark jumping or any damaged vac lines,, check out and compare each plug for its looks and burn.  If you have to ,, clean them with a wire wheel and install them for about a week.  remove them then compare to find and odd ball cylinder.  if you find something drastic looking like a completely black plug, do a compression test on all cylinders.
if the compression test is within 10 or so pounds of eachother, start looking closer at the fuel injector for that cylinder.  Perhaps you can but blame on it if you move the injector to a different cylinder and the problem follows due to the spark plug check you do once again.
a miss will be visible, and your motor will shake a little.  you cant get every siingle miss out of a car , some misses are deeper in your motor such as a valve not closing all the way cause of carbon build up ect.  there are ways to get that taken care of to without tearing down the motor but its usually hit or miss.
Quote from: jcassity;125404
Well what I hear and often is the engine idle seeming to drop sharply for a split second.  And it does tend to shake.
I just looked up the gap for an 88 Mustang...a car I think my Tbird is more similar to than stock, and it says .044.  I think I will gap them down somewhat if only to eliminate the possibility.
....oh and come to think about it I've sprayed water around at night before.  Nothing.
and if you use the old water trick try salt water ;)
From everything I've seen, SO is supposed to be gapped at .044 and the HO is supposed to be gapped at .054...my HO is gapped at .054 with an MSD coil/wires and it runs great.
