Topic: noob engine question (Read 4459 times) previous topic - next topic
how would a 4.6 fit into a tbird isnt the 5 o and 4.6 based on the same block
Yes a 4.6 will fit in a T-bird. It takes some work but it will fit.
On the other hand a 4.6 is in no way similar to a 5.0 except that they both have 8 cylinders. A 4.6 is a modern OHC engine introduced in the 1991 Lincoln Towncar. The 5.0 (302) is a Windsor V8 that is OHV and was first introduced in the early 1960s with a 221 ci displacement. The family includes engines with 221, 260, 289, 302 and 351 cubic inch displacements.
any write ups or any idea how hard it would be to do the swap
bumpity
http://modularfox.com/forums/default.aspx
Dang!!! That's a helluva write-up!!
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Dang, That thing is going to look sweet when done!
I also understand everything he is talking about, yay I do learn things from reading.
Also like the SC on the engine! (Think it is an SC anyway)
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
ok am i blind or what im not seeing what im lookin for
If you've read the article, he has just started the body work and such, on page 4 for you can see him making brackets and the such to mount stuff into the fox.
It is not totally finished.
[Next page is on the bottom]
I was reading a specific article, not the actually forum reference.... sorry of the inconvenience
1992 Ranger 4.0
2019 Ram Rebel
i didnt even see the article till after i had posted that its tiredness on my part
you know, i just had a guy ask if i wanted to trade a 4.6 for my 5.0.  i dunno what shape the 4.6 is in, but mine isnt really all that great.  my rings have gone bad and such...  but putting a 4.6 in the bird looks like a LOT of work.  to much for me anyway.
ya but the low end on the 4.6 is definetly something to look at the 5.0 is to high of a revver for me
Actually from what I read it is almost a direct swap, the only reason it takes time is that people do body work and the such.
**Not an expert, just read**
1992 Ranger 4.0
2019 Ram Rebel
Quote from: koldhearted1;124628
quite the opposite realy. if a 5.0 revs too high for you a 4.6 (specially the dohc) is a MUCH higher revving engine so it likely wont be for you. i shift mine at over 7200rpm. they they have a steep torque curve, they dont make much low end power. the 5.0s are much torquier down low. they have a much more linear torque curve...
~John~
Quote from: xr7cat;124647
um, no. unfortunately its a pretty involved swap. id love to see more of these done around here...
~John~
