Topic: Headlight lenses (Read 1324 times) previous topic - next topic
Headlight lenses
The passenger side headlight lense on my Cougar is starting to come away from the rest of the headlight assembly.  So far it's just the bottom corner, but it's obviously going to get worse. From how it looks I am thinking I can 'help' it the rest of the way off :hick: and then put it back on with some sort of glue or sealer.. I'm wondering what kind of stuff you would use to do this?
1985 Thunderbird turbo coupe - 12.65 @ 105 MPH on an IHI.
1984 CR500 - my hurt my self all the time toy.
Pics of all my junk here.....
Headlight lenses
I used clear silicone in the housing, pressed the lense back in and held together for about 5 min. Let it dry and trimmed off the excess. It has held fine and no moisture inside
Headlight lenses
I got permatex adhesive for lenses. Great bond with no problems what-so-ever.
Your lense will pry off fairly easily. Use a putty knife or a small flathead screwdriver to gently pry it away from the housing, easy as pie.
Headlight lenses
Thanks, next warmer day we have I am going to fix it.
