Topic: shaving emblems (Read 1467 times) previous topic - next topic
shaving emblems
ok i wanna shave the emblems to give it a cleaner look. now when i remove those emblems will there be any sun damage under there once i remove the snot.
shaving emblems
Quote from: 87fordboy;123456
they have small studs on all the emblems even if you get the glue off (wich is rock hard) you will have small holes
quarters,nose,trunk
shaving emblems
does the one from the dealer have studs? looks to me like its just glued on
shaving emblems
The trunk emblems are 3m taped on,that i do know,both my bird's have been this way.
The front and side are bolted on, so bodywork will be required in these areas.
shaving emblems
Quote from: dominator;123462
the turbocoupe is taped, the thunderbird has 2 small  alighment pins
shaving emblems
Oh and yes, as you asked, there will be an outline from the emblems visible in the paint because the paint behind them won't have faded like the rest of the car.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
