Topic: Help!! Engine belt tensioner worn... (Read 1395 times) previous topic - next topic
Hello everyone,
First time posting here. I have a 1988 Mercury Cougar 3.8L and the engine belt is being cut on the sides. Been through 2 belts this month. I took it to my trusted mechanic and he says the belt tensioner is pen 15ed to 1 side, no longer straight, and needs to be replaced. Problem is, he's jumping through hoops on fire in order to locate 1 and it's been 5 days and he hasn't been successful.
Please, someone on here has to know what I can do in order to replace this tensioner.
Thanks!
Factory Air brand Idler Pulley/tensioner assembly
Part Number: 45964
36.96 list price at http://www.partsamerica.com (advance auto)
Dayco Idler Pulley/tensioner assembly
Part Number: 89031
25.94 list price
Hello there Sleeper T-Bird 87,
Thank you for your help and reply. Unfortunately this is not the belt tensioner I need. The belt tensioner I need looks more like this:
http://www.goodyearbeltsandhose.com/cars/tensioners.html
The part you supplied it the idler tensioner.
Thanks again!!
Quote from: c0ugar2;123452
Thanks again!!
try this, it is by chance the right part. it showed these when i looked up 88 thunderbird 3.8 insted of cougar
Dayco Belt Tensioner
Part Number: 89247
Goodyear Belt Tensioner Assembly
Part Number: 49227
Okay bud, will do! I'll check them out tomorrow and print that out for my mechanic to see. But before I do, I see that reference in the table they feature under the link I gave you and the year they list is 89-99.
Make/Model  Year    Dayco  Goodyear
Car   3.8L    89-99   89247   49227
Can you confirm that you found the tensioner under the year 88'
Thanks a whole lot for your time. Really appreciate it.
The two belt tensioners on an 88 are a one year only thing.  Its very hard to find anything to fit the 88 v6.
Quote from: CougarSE;123480
The belt tensioner that SLEEPER T-BIRD found will not work? If that is the case, what do you recommend I do? This car can't move without a belt tensioner. Seems it getting harder and harder to hold on to this car.
I duno..  I'll be at the junkyard tomorrow where there is an 88 3.8 tbird.  if it has a good tensioner I'll take it off.
Thank you so much for offering to do that.
Quote from: SLEEPER T-BIRD 87;123448
Part Number: 45964
Part Number: 89031
25.94 list price
that is for the 87 and earlier 3.8 and 85 or earlier 5.0.
tray also the 4.2L equipped vehicles like the winstar.  the 4.2 is a stroked  3.8  and different airflow setup.
