Topic: motor mounts (Read 977 times) previous topic - next topic
motor mounts
does anyone know a good place to jack up the motor? i have never done this b4 i have a set of directions but it says to read the servicec manual which i no longer have
motor mounts
whenever I have to lift the engine in my 79 cougar (5.0) I undo the mounts and jack up on the trans bell housing.
motor mounts
I usually put a big flat piece of wood on my floor jack and lift under the oil pan.Never had any problems with that in all my years.
motor mounts
What's up!:grinno:
 I'm new to the board. I agree with the other guys. I've used a bottle jack under the balancer and also unbolted the nuts off the trans mount and the bolts on the fan shroud. Sometimes the mounts are a tight fit and lifting the motor helped some;) If you don't mind me asking where did you get your mounts from? The parts guy asked me if my vehicle was Canadian because that's all he showed for a V-8:rollin: He sold me 2 Doan 2661SR. I hope they work, since the Ford guy told me they were discontined. If my memorey serves me I believe there were 2 separate Ford #'s though. I just thought you might have some part numbers handy.
Thank much
Mike
motor mounts
Quote from: vinnietbird;123191
+1
