Topic: New or refurbished Headlamp capsules (Read 3181 times) previous topic - next topic
I wonder where i could find some really nice headlamp capsules
turnlamps and parklamps for my 87 TC frontend. Mine are so faded up I cant see anything when i drive at night. any info would be sweet.
1999 Trailblazer(wifes rig)
Check ebay, there is a place sells the pair for 130. I had the same problem. I polished them and it helped a bit but actually only takes the yellow off. The reflective part inside was worn on mine so it only made for a clear dim light. New lights made the difference.  I considered used but found they went for nearly the same money and of course were just as old as what I had already.
i polished mine,but they get full of water all of the time.
I have seen them on ebay,thanks for input.
i need a rh parklamp capsule for my car. Any layin around anybody.
Which ones get full of water?
The inner markers and corner lamps have holes in the bottom so water should drain out of them. If you're getting water in the headlights, they probably need the lenses resealed.
I'm on the process of cleaning mine up right now. Wet sanded the lenses with 1500 grit, then gonna clean them up with polish. They're already looking better and I've only done the sanding.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Ford still sells the headlights new
http://cgi.ebay.com/ebaymotors/2for1-HEADLIGHT-s-87-88-T-Bird-Thunderbird-1987-1988_W0QQcmdZViewItemQQcategoryZ33710QQihZ001QQitemZ110077497199QQrdZ1
Quote from: SLEEPER T-BIRD 87;122865
Yea they do
EDIT  originally entered # for headlight assembly not lens  these numbers are right....Thanks Seek
E7SZ-13007-A   PASSENGER HEADLIGHT
E7SZ-13007-B   DRIVER HEADLIGHT
they are about 45 bucks each online  at places like fordparts.com
you gotta use your old backing plates  you can get new adjuster screws too if yours are shot
E7SZ-13032-D HEADLIGHT ADJUSTER SHORT
E7SZ-13032-C HEADLIGHT ADJUSTER LONG
Quote from: mjbtbrd;123077
Yea they do
E7SZ-13008-A   PASSENGER HEADLIGHT
E7SZ-13008-B   DRIVER HEADLIGHT
Have you looked at the fordparts prices? $150/ea
1988 Thunderbird Sport
Quote from: Seek;123102
you are correct sir  my mistake.......those numbers are the lens and backing plate  the number for just the lenses are
E7SZ-13007-A   HEADLAMP  RIGHT
E7SZ-13007-B   HEADLAMP LEFT
$45.25 ea
Yeah, that there's what you want. I wonder how long they'll keep selling these things
Quote from: mjbtbrd;123105
$45.25 ea
It doesn't show a pic. Is this just the front lense part or the whole bucket with the reflector inside?
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
