Topic: Changed EGR...Now I wait and See....READ LAST POST BIRDMAN! (Read 21446 times) previous topic - next topic
Really? I knew they checked codes...but not those.
-DMC24guy
[/SIZE]
Check your vacum lines. If there is a hole on the one to the map sensor then it will not work right.
Quote from: blu84302;122792
Autohole, can check your TFI and your map sensor and tell you if they need replaced.
Oh god, John and I know way too much about what Autohole can test.
When you say "Autohole", I take it you mean Autozone right? If so, what would I say to them? "I'm going to need you to go ahead and Check my TFI module. So, if you could get working on that as soon as possible...that would be great."
-DMC24guy
[/SIZE]
I had something similar happen with my Sport, and it turned out to be the PIP in the distributor.
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
I second the idea of the TFI. The TFI of my car just died like 2 years ago. The symptoms are almost the same you have described. Try first what Eric said.
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Quote from: Warbird9;122885
when mine did that exact same thing, i just replaced the distributor (after checking the tfi and wtf ever i tried. i can't remember). forget trying to change out that  inside the distributor. total PITA. well, in a thunderstorm it is anyways. prolly still a PITA anyways.
+1 on the ignition switch
I had a similar problem with my car when i was on my way to work. It turned out it was my ignition switch FELL APART. I pulled the cover off the steering column to check the wiring it fell out i had to drive around holding the thing together so i could get a new switch.  It was very touchy with the key too if the key turned back just a tiny bit too much it would shut off. So thats the first thing i would check.
Ok guys. It's panic time for me. It's now just 6 days before I'm supposed to go up to phoenix and trade my car for a Turbo Coupe, but once again, it's experiencing problems. (I swear it knows I'm trying to get rid of it and is punishing me!)
I changed the Fuel Pump two days ago. The Fuel Filter at the same time. The pressure regulator about a month ago. Plugs shortly after that. TFI module on Wednesday. I thought I did everything I could, yet....
Today, I'm driving to work. Everything is seemingly fine for the first....12 miles. Then a red light. Traffic backs up, and I come to a stop. The engine is idling at 600rpm, but is a little rough. It fluctuates down a little, and then, blah! It dies on me!!!!!!!!
I can't believe it. It restarted right away and move forward a couple feet and it dies again. I restarted it successfully, and pulled into the right lane, hazards on and all. I keep it going long enough to get onto a side street and floor it to work. When I have it at speed, it doesn't die. When I came to a light, I put it in park, and revved the engine to keep it from dying again. Luckily I made it to work.
But now I'm left with the sinking feeling that there is still something wrong with the car and I can't find it. I mean, what left is there to change?????
My plan right now is to start using 91 octane gas from here on out, and perhaps dump some octane boost and Fuel Injector Cleaner in it, and hope for the best. I'll have to take the freeway to work everyday to keep it from stalling out I guess.  it! 1 freaking week from getting rid of this thing, and it starts acting up again!
Please help guys. I'm at my wits end. I have to work most days this week, so working on the car will be limited to Tuesday, my only other day off expect for Friday, which is when the trade is supposed to go down.
Suggestions anyone!?
-DMC24guy
[/SIZE]
bump the timing.. it sounds like its idling too low... my LX did that when I first got it.. it absolutly hated reverse...
I do feel like it's always been idling too low for some reason. I'll do anything to fix it. I mean, hell I'm going to be giving up an extra 20 cents to put in high octane gas from here to friday. (Someone told me that would help?)
Ok, How do I bump the timing? Please tell me. [SIZE="5"]FOR GOD'S SAKE, PLEASE TELL ME!!!!![/SIZE]
-DMC24guy
[/SIZE]
you loosen the distributor hold down.. its a 1/2 inch spen 15et.. that and a long extention... loosen it a little bit and nudge the distributor clockwise... not much.. just a little bit.
undo the bolt that holds down the thick hold-down clip thing-chunk-o-metal and rotate your distributor. (not sure which way sorry but thats how to change it)
any possibility that your gas station is giving you shiznitty gas? friend's dad's 99 expedition wouldnt idle when he got some gas that was probably cut with a lot of water. had to rev it sitting at the light or it would shut off. i think dry-gas (isopropol gas line antifreeze) fixed it.
you could try dumping a bunch of that in. or injector cleaner, other additives.
how is the QUALITY of the idle. still fluctuating? or smooth, and just too low? thats why no one has suggested adjusting the idle up until this point im sure.
but IF the idle is SMOOTH then maybe you could just adjust it. theres a way you have to do it with the idle stop screw so that the computer and IAC learn the new idle then you set the screw back to closed or something and the IAC will open more and keep the right idle.
search this place, specifically engine tech, if not google it or best bet search www.corral.net forums in the "5.0/5.8 engine tech windsor engine forum" i believe its been discussed before there
you're in my prayers, man!!! what a py situation. i really hope the thing behaves so you can get that TC.
and if a problem comes up for him within a week after he bought it from you even, you're selling it "AS IS" so one its theirs, its THEIRS, they cant hold you responsible.
as long as it works while he tests it and maybe like a couple days afterward :giggle:
yeah yeah thats not totally honest but like if soon after he buys it the TPS or a sensor or something goes thats not your responsibility. again "AS IS"
GOOD LUCK MAN!!!!
Ok, I'll bump the timing. I also plan on using 91 octane gas from now until Friday as well. If I can, I'll pick up some Fuel Injector cleaner and some other additives that I think might help. I've just got the keep the car in good running order for 1 more week. If I can doctor it up enough so it won't stall out on me, I'll be golden. If not....suicide.
EDIT:(The Idle is smooth sometimes, and other times, it fluctuates up and down. When the idle is rough, you can feel it. I can feel it anyway. The whole car just ever so slightly shakes. It's un-nerving as usually I know what's going to happen at that point.)
So, is bumping up the idle as simple as turning the Distributor clockwise slightly? Or is there more involved???
-DMC24guy
[/SIZE]
