Topic: Changed EGR...Now I wait and See....READ LAST POST BIRDMAN! (Read 19943 times) previous topic - next topic
Reply #180
Ok, checked the codes with the Engine running this time, and pulled the following:
21
34
74
77
Too many if you ask me.
(pulled the electrical connector off the IAC and the engine sputtered and died, so I don't think that's bad.)
-DMC24guy
[/SIZE]
Reply #181
dude go here http://fordfuelinjection.com/?p=14 theres all the codes you need, and they have columns for when you found em aka KOEO etc...
it helps a lot more if you can report the condition, not just the code. i doubt everyones got em memorized. just to dang many of em.
i dont know if this is of any use but i know i tested this once wih my car (unplug the IAC) and when it was cold it died right off the bat. but when warmed up it actually ran. the idle was LOW but it did run. maybe my throttle stop screw is holding the throttle open a little? just food for thought...
Reply #182
Ok well, lets see here:
21-   ECT out of self test range 0.3 to 3.7 volts. -Don't have a clue
34-    PFE or EVP circuit above the closed limit of 0.67 volts. -Again, don't know what this means.
74-    Brake On/Off switch not actuated during KOER test (user error).
77- System failed to recognize brief WOT during Dynamic Response Test (user error).
It's funny, because some sites say that code "34" means No EGR flow and others say different stuff. What am I to believe? Should I take off the EGR just for the heck of it?
-DMC24guy
[/SIZE]
Reply #183
I think the TC throws a 34 even though there is no issue  because of some recall that was done.  You may or may not have egr issues but  it does explain a possible 34 code
21  will come up if you run codes on a cold engine.  If engine was at operating temp  you may need a ect sensor, or have a problem in that circuit.
as already mentioned  fordfuelinjection.com is a great resource.
I  remember doing the code pull thing in 1985  no internet or anything  just some service literature I pulled at the library......those were the days  LOL
Reply #184
start throwing snow balls now cause all you guys are freaking idiots for using and promoting that  site - fordfuelinjection.com
The guy can't solder nor does he point out the correct preparation to solder correctly,,, he fails to mention critical steps that probably caused you to get codes 74 and 77,(cut the wheel, step on the brake ect prior to even pulling codes), the list goes on and on and this guy has said you can clear the codes on your computer by just unhooking the battery for 15min!!!!!!!!!!!!!!!!!.  The only way to clear any codes is to unhook the sig rtn to sti connection during the time in which that specific code is being dumped out to you.
he also says you can use your digi meter to pull codes if you leave it set on continuity to listen for the beeps,, now thats curious,, ill have to jump right on that and set my meter to resistance and let current pass thru my "ohmmeter".
i looked at those code pulling instructions for some time trying to figure out what the heck to do and i got lost.  seems to me that i would have my sti and sto hooked up to the neg bat terminal as far as i could tell.
I use the voltmeter method and use a 12vdc buzzer instead of the actual meter.
this guy does not even make mention of what to do with the Signal Return connection.
stupid,,,,,,,,,,,,,stupid,,,,,,,,,,,,,,,,stupid.
you need to start over and follow the instructions here,,,,,,,,,
http://www.therangerstation.com/tech_library/OBD_I.html
the fuelinjection.com site might have some goodies but just the fact that each tab i looked at had some problem, it bugs me.  Take for instance the "Tech"  secion on relays.  A man would think there would be some "above and "beyond" information on relays,,,well,,, there was nothing inpressive.
Reply #185
Here a chart of common TC EEC Codes... for the ones not listed just do a search on NATO.
http://www.turbotbird.com/techinfo/eec.htm
Reply #186
i dont know why youd have to do a search
the 74 and 77 codes are your fault ,, you did not do the test properly.
[COLOR="Blue"] TheRangerStation.com[/COLOR]
Your 'Original' Ultimate Ranger Resource!
Serving Ranger, Bronco II, Explorer and Mazda B-Series Enthusiasts.
 Clearing Codes
These codes are kept in memory for 40 warm up cycles.  To clear the codes for purposes of  testing or confirming repair, perform the code reading procedure.  When the fault codes begin to be displayed, de-activate the test by either disconnecting the jumper wire or releasing the test button on the hand scanner.  Stopping the test during code transmission will erase the continuous memory.  Do not disconnect the negative battery cable to clear the codes; the keep alive memory will be cleared and a new code (19) will be stored for loss of PCM power.
Malfunction Indicator Lamp (MIL) Method ***using your [COLOR="Red"]check engine [/COLOR]light as the test light.
The Malfunction Indicator Lamp (MIL) on the dash (Engine Light) can be used to retrieve the stored codes.  This method does not allow for any system investigation.  This should only be used in the field where quick checks are needed.  Follow the directions previously given for the scan tool procedure.  To activate the tests, use a jumper wire to connect the signal return pin on the diagnostic connector to the Self-Test Input (STO) connector.  The self test input line is the separate wire and connector with or near the diagnostic connector.  Codes are transmitted with a pause between flashes.  Code 32 would be sent as 3-flashes, a pause and then 2-flashes.  A slightly longer pause separates the codes. The only way to repeat the code is to recycle the system.  The Continuous Memory Codes are separated from the other codes by 6-seconds, a flash and then another 6-second delay.  Compare the 2-digit and 3-digit Diagnostic Codes with the appropriate chart[COLOR="red"].********FOR THIS METHOD, YOU DONT NEED A METER OR A TEST LIGHT, JUST A PAPERCLIP*******[/COLOR]
[COLOR="Red"]((SEE DIAGRAM AT THE BOTTOM OF THIS POST FOR HOW TO INSTALL YOUR PAPERCLIP ONLY)))[/COLOR]
KEY ON ENGINE RUNNING (KOER) TEST
1.  Make sure engine is fully warmed. If in doubt, run engine at 2000 rpm for 2 minutes.
2.  Turn ignition off and wait 10 seconds for system to shut off. Make sure A/C is off and transmission is in Park (automatic) or Neutral (manual).
3.  Hook up light and jumper (or tester if you have one).
4.  Make sure vehicle is safe to run and start engine.
5.  Engine I.D. should be output.
6.  Step on brake and turn steering wheel 1/4 turn. If the vehicle has an overdrive cancel switch, push it.
7.  If a "Goose" pulse is received, move throttle quickly 1/2 way down and release.
8.  Fast Codes are output (ignore).
9.  Read codes.
10. See code explanations and check components as necessary.  Use FIRST CODE OUTPUT and retest after any repairs are made.
Home Search Forums Chat Tech Library TRS Fab & OffRoad Events Magazine
OBD-I Diagnostic Trouble Code (DTC)  Applications
2-Digit Codes (All Fords)
Differences in test mode noted as:
(O) = Key On Engine Off test
(R) = Key On Engine Running test
(M) = Memory code
Code Definition
11
 System checks OK
12
 Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
13 (O) ISC did not respond properly (extends to touch throttle then retracts for KOEO) - ISC
 (R) Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
 (M) ISC sticking, open ITS circuit or TP sticking
14 Ignition pickup was erratic - Ignition Systems
 E4OD Transmission diesel RPM sensor - Diesel RPM sensor
15 (O) No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
 (M) KAM (pin 1) was interrupted (was battery disconnected ?)
16 1.9L & 2.5L - Throttle stop set too high - IDLE or Idle Set Procedures
 2.3L - RPM's too low - IDLE
 (O) Electronic ignition - IDM circuit fault - Ignition Systems
17 1.9L & 2.5L - Throttle stop set too low - IDLE
18 (R) Check base timing & advance function - Timing Tests
 (M) Ignition TACH signal erratic - Ignition Systems
19 (O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
 (R) Erratic idle during test (reset throttle & retest) - Idle Set Procedures
 Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
21  Engine Coolant Temperature (ECT) sensor out of range - ECT
22  MAP (vacuum) or BARO signal out of range - MAP
23  Throttle sensor out of range or throttle set too high - TPS
24  Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range - IAT VAT
25  Knock sensor not tested (ignore if not pinging) - KS
26 Mass Air Flow (MAF) or Vane Air Flow (VAF) out of range - MAF VAF
 Transmission Oil Temperature (TOT) sensor out of range - Transmissions
27  Vehicle Speed Sensor problem - VSS
28 Vane Air Temperature (VAT) sensor out of range - VAT
 2.3L w/Electronic Ignition - Cyl ID, IDM low or right coil pack failure - Ignition Systems
29  Vehicle Speed Sensor problem - VSS
 EGR CODES DEPEND ON WHAT SYSTEM TYPE THE VEHICLE IS EQUIPPED WITH:
 EVP is for vehicles equipped with EGR solenoid(s), with or without an EVP sensor
 EVR is for vehicles equipped with an EGR Vacuum Regulator (EVR) and an EGR Valve Position (EVP) sensor
 PFE is for vehicles with Pressure Feedback EGR (PFE) sensor and and an EGR Vacuum Regulator (EVR)
 If you don't know what type of system you have, go to the EVP heading, which is the first one.
 There are pictures under the different headings to help you identify the system.
31 EVP - (O, R, M) EVP signal is/was out of range - EVP
 EVR - (O, R, M) EVP signal is/was low - EVR
 PFE - (O, R, M) PFE signal is/was low - PFE
32 EVP - (R) EGR not responding properly during test - EVP
 PFE - (R, M) PFE shows low pressure, EGR not seating or memory, not seating intermittently - PFE
33  ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
34 EVP - (R) EGR did not respond properly during test - EVP
 EVR - (O, R, M) EVP sensor is/was high - EVR
 PFE - (O, R, M) PFE sensor is/was out of range - PFE
35 EVP - (R) Engine RPM's too low to test EGR system - EVP
 EVR - (O, R, M) EVP sensor signal is/was high - EVR
 PFE - (O, R, M) PFE sensor signal is/was high - PFE
38  Idle Tracking Switch signal was intermittent - ISC
39  Transmission Torque Converter clutch not engaging - Transmissions
40  SERIES FUEL/AIR INJECTION CODES ON VEHICLES WITH DUAL OXYGEN SENSORS REFER TO THE RIGHT OR REAR SENSOR. EXCEPT: 1984-1988 3.8L ENGINES: LEFT SENSOR
41 (R) System lean - Fuel control
 (M) System was lean for 15 seconds or more (no HO2S switching) - Fuel control
42 (R) System rich - Fuel control
 (M) System was rich for 15 seconds or more (no HO2S switching) - Fuel control
43  (R) HO2S sensor not reading (run at 2000 rpm's for 2 minutes and retest - check for HO2S switching)
 (M) Was lean at WOT for 3 seconds or more - Fuel control
44  AIR system inoperative - Air Injection
45 AIR not Diverting (AIRD) - Air Injection
 Electronic Ignition - coil primary circuit failure - Ignition Systems
46 AIR Bypass (AIRB) not working - Air Injection
 Electronic Ignition - primary circuit failure coil 2 - Ignition Systems
47  Low flow unmetered air (check for small vacuum leaks, injector o'rings, gaskets etc.)
 E4OD transmission 4x4 switch/circuit problem - Transmissions
48 High flow unmetered air (check for large vacuum leak, inlet hoses etc.)
49 Electronic Ignition - spout signal circuit problem - Ignition Systems
 Transmission 1/2 shift problem - Transmissions
51  Engine Coolant Temperature (ECT) sensor signal is/was too high - ECT
52 Power Steering Pressure Switch/circuit open - PSP
 (R) Did you turn wheel during test ?
53  Throttle Position sensor too high - TPS
54  Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high - IAT VAT
55  No or low (under 7.5 V) Key Power to PCM pin 5
56 Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high - VAF MAF
 Transmission Oil Temperature sensor too high - Transmissions
57 Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit - PNP or Transmissions
 1990 Scorpio - Octane jumper installed (information only code - to inform you if it is installed or not)
58 Idle Tracking Switch (ITS) signal problem ISC
 Vane Air Temperature (VAT) sensor out of range or open - VAT
59 AXOD 4/3 circuit fault - Transmissions
 3.0L SHO - Low speed fuel pump circuit problem - Power / Fuel Pump Circuits
 Transmission 2/3 shift problem - Transmissions
 1990 Scorpio - Idle jumper installed (information only code - to inform you if it is installed or not)
61  Engine Coolant Temperature (ECT) sensor is or was too low - ECT
62 AXOD (KOEO only) 3/2 circuit short to ground - Transmissions
 AXOD (KOEO AND KOER) 4/3 circuit failure - Transmissions
 E4OD excessive converter clutch slippage - Transmissions
63  Throttle Position Sensor (TPS) signal too low TPS
64  Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal low or grounded - IAT VAT
65 Check intermittent HO2S (signal or ground) - Fuel Control
 (R) E4OD truck - cycle OD cancel switch after engine ID is received - Transmissions
 1984 3.8L ONLY - O, M Battery voltage high (check for electrical system overcharging)
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
 Transmission Oil Temperature (TOT) signal low (possibly grounded) - Transmissions
67 Park/Neutral circuit fault - PNP
 Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
 (M) Intermittent Park Neutral Position (PNP) sensor fault - PNP
68 Idle Tracking Switch (ITS) circuit (possibly grounded) - ISC
 Vane Air Temperature (VAT) sensor out of range or grounded - VAT
 3.8L AXOD -Transmission Temperature Switch (TTS) open - Transmissions
 Electronic Transmission - Transmission Oil Temperature (TOT) sensor was overheated - Transmissions
69 AXOD transmission (O) 3/2 switch closed (possible short circuit) - Transmissions
 AXOD (M) 3/2 switch open (poss short to power) - Transmissions
 E4OD 3/4 shift problem - Transmissions
70 (M) 3.8L AXOD - Data link to instrument cluster fault. Service any other EEC codes, erase memory and retest.
 If code is still present refer to instrument cluster diagnosis manual.
71 (M) 1.9L TBI, 2.3L TBI, 2.5L TBI - ITS signal was grounded when throttle should have been opening ITS - ISC
 ISC motor problem or Idle Tracking Switch (ITS) signal wire shorted to ground - ISC
 (M) 1.9L MFI - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
 (M) 3.8L AXOD - Data link to instrument cluster fault - See code 70
72 (R) No MAP or MAF change in "goose" test - retest, check for frequency or voltage change - MAP MAF
 (M) 1.9L MFI - VPWR circuit to PCM was intermittent - VPWR Diagnosis
 (M) 2.3L T/C - PCM re-initialized. Possible electrical noise, case ground or intermittent VPWR problem -  VPWR Diagnosis
 (M) 3.8L AXOD - Message center data link circuit fault - See code 70
73 (O) Rerun test, if 73 is still output replace TPS
 (R) No Throttle Position Sensor (TPS) change in "goose" test. Must get at least 25% throttle rotation - TPS
74 Was brake depressed after engine ID was received ?
 Brake On Off (BOO) signal open or short to ground - BOO
75  Brake On Off (BOO) signal shorted to power - BOO
76 Vane Air Flow (VAF) did not respond to "goose" test - VAF
77  System did not receive "goose" test - see TESTS
78  (M) VPWR circuit to PCM was intermittent or the PCM is bad VPWR Diagnosis
79  A/C is on or pin 10 is shorted to power
80  SERIES CODES GENERALLY ARE CIRCUIT PROBLEMS THAT COULD BE WIRING, RELAY OR SOLENOID RELATED.
 ONLY ONE OF THE CIRCUITS LISTED UNDER THE CODE IS USED ON EACH VEHICLE. THE FAULT IS IN WHICHEVER SOLENOID OR CIRCUIT IS PRESENT ON THE VEHICLE
81 Boost control solenoid - Solenoids
 AIRD solenoid - Solenoids and Air Injection
 3.0L SHO - Inlet Air Solenoid - Solenoids
82 2.3L TC - Fan Control wire shorted to ground - A/C and Fan Circuits
 AIRB solenoid - Solenoids and Air Injection
 3.8L SC - Super Charger Bypass Solenoid - Solenoids
83 High Electro Drive Fan circuit fault - A/C and Fan Circuits
 EGR Control solenoid - Solenoids
 3.0L SHO - Low Speed Fuel Pump Relay circuit - Power / Fuel Pump Circuits
84 EGR Vacuum Regulator - Solenoids
 EGR cutoff solenoid - Solenoids
 EGR Vent solenoid - Solenoids
85 2.3L T/C Automatic - 3/4-4/3 Shift solenoid - Transmissions
 CANP solenoid (ALL 1989) - Solenoids
 (M) 1.9L MFI - System has corrected rich condition - Fuel control
86  2.3L or 2.9L Truck - A4LD 3/4 shift solenoid - Transmissions
 (M) 1.9L MFI - System has corrected lean condition - Fuel control
87 (O) Fuel pump circuit fault (check inertia switch) - Power / Fuel Pump Circuits
 Vehicles with 2BBL carb - Temperature Compensated Accelerator Pump Solenoid - Solenoids
 (M) intermittent in fuel pump primary circuit - Power / Fuel Pump Circuits
 NOTE: On some Escorts with automatic seat belts this code is normal IN MEMORY due to the wiring
88 Throttle Kicker Solenoid - Solenoids
 Variable Voltage Choke relay circuit fault - VVC
 Fan Control circuit fault - A/C and Fan Circuits
 A4LD - Converter Clutch Override solenoid - Transmissions
 Electronic Ignition - IDM, DPI or spout circuit fault - Ignition Systems
89 A4LD - Converter Clutch Override solenoid - Transmissions
 AXOD Torque Converter Control solenoid circuit - Transmissions
 Exhaust Heat Control (heat riser) solenoid circuit - Solenoids
90 SERIES FUEL/AIR INJECTION CODES ON VEHICLES WITH DUAL OXYGEN SENSORS REFER TO THE LEFT OR FRONT SENSOR. EXCEPT: 1984-1988 3.8L ENGINES: RIGHT SENSOR
91 (R, M) System running lean - Fuel control
 Transmission SS 1 circuit/solenoid problem - Transmissions
92 (R) System running rich - Fuel control
 Transmission SS 2 circuit/solenoid problem - Transmissions
93 (O) Throttle linkage binding or bad ISC motor ISC (R) HO2S not reading - Fuel control
 Transmission TCC circuit/solenoid problem - Transmissions
94 AIR system inoperative - Air Injection
95  (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
 (R) AIR not Diverting (AIRD) - Air Injection
 (M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
96 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
 (R) AIR Bypass (AIRB) not working - Air Injection
 (M) (Service 87 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
97  E4OD OD cancel light circuit failure - Transmissions
98  (R) Did not pass KOEO yet (Get 11 in KOEO first)
 Transmission EPC circuit/solenoid failure - Transmissions
99 (R) ISC needs to learn (Let idle for 2 minutes; Erase memory and retest)
Definitions
ACT  Air Charge Temperature Sensor / BP See MAP /
EEC  Electronic Engine Control System
ECT  Engine Coolant Temperature Sensor
EGR  Exhaust Gas Recirculation Valve
-- EVP  Valve Position Sensor
EGR  / HEGO  Heated Exhaust Gas Oxygen Sensor
KOEO  Key On Engine Off
KOER  Key On Engine Running
MAF  Mass Air Flow Sensor
MAP  Manifold Absolute Pressure Sensor
MLP  Manual Lever Position
PCM  Powertrain Control Module
SPOUT  Distributor Jumper to Allow Initial Timing
TP  Throttle Position Sensor
SM  TheRangerStation.com
3-Digit Codes (All Ford)
(M) = Memory code
Code Definitions
111  System checks OK
112  (O,M) Intake Air Temperature (IAT) sensor is/was low or grounded - IAT
113  (O,M) IAT sensor is/was high or open - IAT
114  (O,R) IAT sensor out of range - IAT
116  (O,R) Engine Coolant (ECT) sensor out of range - ECT
117  (O,M) ECT sensor is/was low or grounded - ECT
118  (O,M) ECT sensor is/was high or open - ECT
121  (O,R,M) Throttle Position (TP) sensor out of range - TPS
122  (O,M) TP low (possibly grounded or open circuit) - TPS
123  (O,M) TP is/was high or short to power - TPS
124  (M) TP voltage was higher than expected - Fuel control
125  (M) TP voltage was lower than expected - Fuel control
126  (O,R,M) MAP or BARO sensor out of range - ">MAP
128  (M) MAP vacuum has not been changing - check vacuum lines - ">MAP
129  (R) No MAP or Mass Air Flow sensor change during "goose" test - MAP MAF
136 (R) Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
137 (R) Oxygen sensor not switching/system rich Left or Front HO2S - Fuel control
138 (R) Fault in Cold Start Injector circuit - Fuel control
139 (M) Oxygen sensor not switching Left or Front HO2S - Fuel control
144 (M) Oxygen sensor not switching Single, Right or Rear HO2S - Fuel control
157  (R,M) Mass Air Flow signal is/was low or grounded - MAF
158  (O,R,M) MAF sensor is/was high or short to power - MAF
159  (O,R) MAF sensor is/was out of range - MAF
167  (R) No Throttle Position sensor change in "goose" test (must get at least 25% rotation) - TPS
171 (M) Oxygen sensor not switching - system was at adaptive limits - Single, Right or Rear HO2S - Fuel control
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
173 (R,M) Oxygen sensor not switching - system is or was rich - Single, Right or Rear HO2S - Fuel control
174 (M) Oxygen sensor was slow in switching Single, Right or Rear HO2S - Fuel control
175 (M) Oxygen sensor not switching - system was at adaptive limits - Left or Front HO2S - Fuel control
176 (M) Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control
177 (M) Oxygen sensor not switching - system was rich Left or Front HO2S - Fuel control
178 (M) Oxygen sensor was slow in switching Left or Front HO2S - Fuel control
179 (M) Fuel system was rich at part throttle Single, Right or Rear HO2S - Fuel control
181 (M) Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
182 (M) Fuel system was rich at idle Single, Right or Rear HO2S - Fuel control
183 (M) Fuel system was lean at idle Single, Right or Rear HO2S - Fuel control
184 (M) Mass Air (MAF) output higher than expected - Fuel control
185 (M) Mass Air (MAF) output lower than expected - Fuel control
186 (M) Injector pulse width longer than expected or Mass Air Flow (MAF) lower than expected - Fuel control
187 Injector pulse width shorter than expected or Mass Air Flow (MAF) higher than expected - Fuel control
188 (M) Fuel system was rich at part throttle - Left or Front HO2S - Fuel control
189 (M) Fuel system was lean at part throttle - Left or Front HO2S - Fuel control
191 (M) Fuel system was rich at idle - Left or Front HO2S - Fuel control
192 (M) Fuel system was lean at idle - Left or Front HO2S - Fuel control
193 Failure in Flexible Fuel (FF) sensor circuit - Fuel control
194  (M) Perform cylinder balance test to check for inoperative injectors
195  (M) Perform cylinder balance test to check for inoperative injectors
211  (M) Ignition PIP signal was erratic or missing - Ignition Systems
212  (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
213  (R) Ignition SPOUT or SAW circuit open or shorted - Ignition Systems
214  (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
215  (M) Primary circuit failure - ignition coil 1 - Ignition Systems
216  (M) Primary circuit failure - ignition coil 2 - Ignition Systems
217  (M) Primary circuit failure - ignition coil 3 - Ignition Systems
218  (M) IDM signal open or high or left coil pack failure - Ignition Systems
219  (M) SPOUT circuit failure, timing defaulted to 10 degrees - follow code 213 diagnosis
222  (M) IDM open or high or right coil pack failure - Ignition Systems
223  (M) Dual Plug (DPI), SPOUT or IDM circuit fault - Ignition Systems
224  (M) Failure in ignition coil primary circuit - Ignition Systems
225  (R) Knock sensor not tested (ignore if not pinging) - KS
226  (O) Ignition Diagnostic Monitor (IDM) signal fault - Ignition Systems
232  (M) EI primary coil circuit failure - Ignition Systems
238  (M) EI primary circuit failure - ignition coil 4 - Ignition Systems
311  (R) AIR system not working - Single, Right or Rear HO2S - Air Injection
312  (R) AIR not diverting - Air Injection
313  (R) AIR not bypassing - Air Injection
314  (R) AIR inoperative, Left or Front HO2S - Air Injection
326  (R,M) Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittently - PFE
327  (O,R,M) EGR feedback signal is/was low - EVR or PFE
328  (O,R,M) EGR Valve Position (EVP) is/was low - EVR
332  (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
334  (O,R,M) EVP sensor is/was high - EVR
335  (O) EGR feedback signal is/was out of range - EVR or PFE
336  (O,R,M) PFE sensor signal is/was was high - ">PFE
337  (O,R,M) EGR feedback signal is/was was high - EVR
338  (M) Cooling system did not heat up (check cooling system / thermostat operation)
339  (M) Cooling system overheated (check cooling system / thermostat operation)
341  (O) Octane jumper installed (information only code to notify you if it is installed)
411  (R) Idle speed system not controlling idle properly (generally idle too high) - ISC
412  (R) Idle speed system not controlling idle properly (generally idle too low) - ISC
452  (M) Vehicle Speed Sensor (VSS) problem
511  (O) No power to PCM pin 1 or bad PCM (processor)
512  (M) Memory power (PCM pin 1) was interrupted - Was battery disconnected ?
513  (O) Replace processor (PCM) (internal failure)
519  (O) PSP switch/circuit open - PSP
521  (R) Wheel not turned during test or PSP problem - PSP
522 (O) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault - PNP
  transmission MLP sensor out of range in park - Transmissions
524  Problem in low speed fuel pump circuit - Power / Fuel Pump Circuits
525  (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault - PNP
528  (M) System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch) - PNP
529  (M) Data Communications Link to processor failure
  Service any EEC codes, erase memory and retest. If code is still present refer to instrument cluster diagnosis manual.
533  (M) Data Communications Link to instrument cluster failure - see 529
536  (O,R,M) Brake On Off open or shorted to ground - BOO
538  (R) System did not receive "goose" test - TESTS
539  (O) System shows voltage at PCM pin 10. Is A/C on ?
542  (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
543 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
  (M) (Service 556 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
551 Problem in Intake Manifold Runner Control (IMRC) solenoid/circuit - Solenoids
552  (O) AIRB solenoid/circuit failure - Solenoids
553  (O) AIRD solenoid/circuit failure - Solenoids
554  (O) Fuel Press Regulator Control solenoid/circuit fault - Power / Fuel Pump Circuits
556  (O,M) Fuel pump relay primary circuit fault - Power / Fuel Pump Circuits
557  (O,M) Low speed pump relay primary circuit fault - Power / Fuel Pump Circuits
558  (O) EGR vacuum regulator solenoid/circuit failure - EVR or PFE or Solenoids
559  (O) A/C relay primary circuit fault - A/C and Fan Circuits
563  (O) High Fan Control (HFC) circuit failure - A/C and Fan Circuits
564  (O) Fan Control (FC) circuit failure - A/C and Fan Circuits
565  (O) Canister Purge 1 solenoid/circuit failure - Solenoids
566 (O) transmission 3/4 shift solenoid/circuit - Transmissions
569  (O) Canister Purge 2 solenoid/circuit failure - Solenoids
578  (M) A/C pressure sensor VREF short to ground - A/C and Fan Circuits
579  (M) ACP sensor did not change with A/C on - A/C and Fan Circuits
581  (M) Cooling fan current was excessive - A/C and Fan Circuits
582  (O) Open cooling fan circuit - A/C and Fan Circuits
583  (M) Fuel pump current was excessive - Power / Fuel Pump Circuits
584  (M) Open power ground circuit - Power / Fuel Pump Circuits
585  (M) A/C clutch current was excessive - A/C and Fan Circuits
586  (M) Open circuit in A/C clutch - A/C and Fan Circuits
587  (O, M) Communication problem between PCM and Variable Control Relay Module (VCRM) - Power / Fuel Pump Circuits
617  (M) Transmission shift failure (1/2 shift) - Transmissions
618  (M) Transmission shift failure (2/3 shift) - Transmissions
619  (M) Transmission shift failure (3/4 shift) - Transmissions
621  (O) Solenoid/circuit failure - shift solenoid 1 - Transmissions
622  (O) Solenoid/circuit failure - shift solenoid 2 - Transmissions
624  (O,M) Solenoid/circuit failure -Electronic Pressure Control (EPC) current is high - Transmissions
625  (O,M) Solenoid/circuit failure - Electronic Pressure Control (EPC) current is low - Transmissions
626  (O) Transmission Coast Clutch (CCS) Solenoid/circuit fault - Transmissions
627  (O) Torque Converter Clutch circuit fault - Transmissions
628  (M) Excessive converter clutch slippage - Transmissions
629  (O,M) Torque Converter Clutch circuit fault - Transmissions
631  (O) Overdrive Cancel Light circuit problem - Transmissions
632  (R) E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
633  (O) 4x4L switch should be in 4x2 or 4x4 high for the test
634  (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault
  Electronic shift transmission - Manual Lever Position (MLP) sensor out of range in PARK - Transmissions
636  (O,R) Transmission Oil Temperature (TOT) sensor out of range - Transmissions
637  (O,M) TOT sensor is/was high or open - Transmissions
638  (O,M) TOT sensor is/was low or grounded - Transmissions
639  (R,M) Transmission Speed sensor (TSS) circuit fault - Transmissions
641  (O) Transmission solenoid/circuit failure Shift Solenoid 3 - Transmissions
643  (O)(M) Torque Converter Clutch (TCC) circuit - Transmissions
645  (M) Transmission 1st gear failure - Transmissions
646  (M) Transmission 2nd gear failure - Transmissions
647  (M) Transmission 3rd gear failure - Transmissions
648  (M) Transmission 4th gear failure - Transmissions
649  (M) Transmission EPC system failure - Transmissions
651  (M) Transmission EPC solenoid/circuit fault - Transmissions
652  (O) Torque Converter Clutch (TCC) circuit fault - Transmissions
654  (O) Transmission selector not in PARK - Transmissions
656  (M) Torque Converter Clutch (TCC) slip - Transmissions
657  (M) Transmission temperature was excessive - Transmissions
998 (R) Did not pass Key On Engine Off test yet (Get 111 in KOEO first)
  (O) Transmission Electronic Pressure Control (EPC) solenoid/circuit fault - Transmissions
Code Definitions:
BP  See MAP
EVP  EGR Valve Position Sensor
Web Hosting Provided byOnline-Solutions.org
Fast Affordable Hosting You Can TRUST
Reply #187
Quote from: DMC24guy;126804
You have to realize that the only reference material that will that will define the codes specifically for your car are the Ford shop manuals for the year of your car.
These other reference materials are a composit of all years and engines over the life span of the EEC-IV.
Or if in a forum maybe just for the engines and years of vehicles involved in the forum.
There is a lot of commonality between them but also a lot of differances.
The EGR codes refer to PFE and EVP.
You have to know what kind of an EGR system your car has.
PFE uses a pressure feedback sensor.
EVP uses a EGR valve position sensor.
It takes some experience to gleen what applies to your car from the reference material.
Reply #188
Oh for Christs sake. KISS
Keep It Simple Stupid.
Here we go.
Code 34- does the EGR valve have a green and black check valve inline?  If so, your EGR recall has been done, and the code 34 is not a concern.It is NORMAL.
Codes 74 & 77-  Operator error. NOT A CONCERN.
Code 21-Common if you didnt let the car warm up.  If it was warmed up, ask Pete D over on http://www.turbotbird.com to send you the ECT testing proceedure.  A faulty ECT will not always set a code.
ALSO LOOK AT THESE:
http://www.turbotbird.com/techinfo/Idle-TPSadjustment_Revised_June2005.html
http://www.turbotbird.com/techinfo/In_Car_Codes/In-CarCodes.htm
THESE ARE ALL OF THE RESOURCES YOU NEED.
People tend to complicate things WAY too much.
And just for the record, My vote is for your TPS to be way out of range, or a combination of that and the ECT
88 TC, Lots of Mods.
Reply #189
Hey Birdman, yes...you. I don't know if you got my Private Message or not, as I sent it out quite some time ago, but I was wondering if you still have those pictures you took of your Black Turbo about a year ago?
(I agree with keeping things simple by the way. I love KISS'ing things)
-DMC24guy
[/SIZE]
Reply #190
LOL I didnt even see I had a PM untill you pointed it out!!  I'll get them to you ASAp!
Reply #191
Quote from: Birdman;127016
ill play Pete for now,, since the ect test procedure is in my DIY link:D
ECT sensor test
Resistance test pin to pin of the sensor (this is a variable resister proportional to temperature
including outside air temp if the motor is cold)
at 50degF=58K ohms
at 65degF=40K ohms
at 180degF=3.6K ohms
at 220degF=1.8K ohms
Reply #192
Sorry guys I missed the question about pics of my mityvac hand pump.  here is a link to the compnay site. http://www.mityvac.com/  The first page has a pic of the one I have.
