Topic: Lincoln LSC rear end swap (Read 7585 times) previous topic - next topic
At my local junk yard there is a lincoln mark VII. I was planing on getting the 8.8 axle from it (the only drive train part left on it). I've
read that it should have 3.27 cogs and a limited slip (I have 3.73's for an 8.8 inch axle). I'm wondering if it will swap out with my 7.5 rear. Being that the licoln rear end has disks instead of drums, will this create a problem? Any help would be great.
Re: Lincoln LSC rear end swap
It will fit under the car, however the LSC rear is a few inches wider than the fox tbird/cougar rear.  The best fit is a Turbo Coupe (87&88) 8.8" rear.  They come with limited slip 3.55 (stick) or 3.73 (auto).
A fox mustang rear will also work but is 1.5" narrower that the 85-88 tbird/cougar.  And finally, a sn-95 stang rear will work but will have five lug hubs requiring new rims.
Any rear with disks will requre parking break modifications.
All Mark VII's are 5 lug as well. There were different options on the rear, limited and open 2.73s and 3.27s. The earlier marks had 7.5 rear ends. I'm not positive, but I'm pretty sure '88 was when they made the swap to the 8.8s, possibly '87, where is this mark located? I might need the front valance off of it
Uhhhh he said mark IV, I thought those things were huge? My mark VII is pretty big as it is.
I meant Mark VII. sorry about that! guess I don't know my roman numerals very well. And by the way, this lincoln is in a junk yard in Mills,  michigan. I beleve its an 89' because the I took the computer from it and it is mass air not speed density. :brick:
hmmm... mass air eh?  That's news to me.  All Mk VII's were speed density from the factory.
On this non-tbird rear end subject.  I'm getting a Mustang rear, which, as stated, is a bit narrower.  What is it that makes the T-bird rear end wider?  Is there any way I can swap this stuff over onto the Mustang rear so my wheels are out at the correct track width?
The basic difference is the TC axles are wider...the housings are virtually the same so they will swap into the Mustang housing. You would have to use the TC brakes as well.
Quote from: tbirdmanjwg
If has mass air some one converted it, all LSCs were SD from the factory...
I swapped out my rear with the mark VII from a 89 or 90.  I used the arms from the T-Bird.  You will have to run brake lines for it.  Mine worked fine and I can't tell that the rear is wider just by looking at it.
The e-brake cables are a direct swap. I'm using them now with a TC rear, if I had a mark rear I would not have had to modify the ends...
look at the axle code on the door jam, if it's the original axle, it will tell you the ratio as well as wheter or not it's a limited slip or a one legger, I don't remember what letter's represent which rear end set-ups, but I've got that info around the  house here somewhere., what other good parts are left on the Mark?
Quote from: foxford
ummm, well I do recall that the front clip is all there, no engine or trans,all the suspension parts are there, the interior is gutted but the dash and console are still there....
Me and 84blu302 put a 8.8 lincoln rear in his car.  Everything worked great, we just didn't hook up the e brake cables.
