Topic: Changing my Dizzys (Read 2001 times) previous topic - next topic
Changing my Dizzys
:grinno: I got my new one from vinnie:grinno:
what does it take to swap them. I'm going from this
To this
What all is required?
P.S, Fila shot for the road
Changing my Dizzys
Also before anyone asks, the newer rotor doesn't fit the dizzy on teh car. I tried but it just doesn't work
Changing my Dizzys
well if your original dizzy has that big fat plug on it too then id think you could just yank the old one and put in the new one. does it have the plug?
there could be other differences too, wait for some other opinions.
Changing my Dizzys
I believe its a direct swap
Changing my Dizzys
It's a direct swap.Mine had the one with the bigger rotor,and I swapped it for a different one like the one I sent you.Now I have the H.O,but it swapped right over with no worries.
P.S.,Did you see my birthday message?
Changing my Dizzys
Yeah Vinnie, I saw it. But don't you have to, when going from one to the other, have to rotate the rotor 180 or something like that? Or just pull and drop in?
Changing my Dizzys
Note the location of the rotor on the old one,and put the new one in the same spot.
Changing my Dizzys
Aight guys, I'll probaly do this today or tomorow. Expect pics soon ( after 3, I have school)
Changing my Dizzys
Good luck !!!
Changing my Dizzys
Sorry guys, I lied. I just got home. I may wait till tomorow or I may do it now. Pics and time will tell
Changing my Dizzys
Just finished. You can feel the difference it made in the car. Really can't explane it. It just runs better.
Changing my Dizzys
plug and play,,
im hoping you marked the rotor to the dizzy and the base of the dizzy to the intake with a marker or sumthin,, anyway, congrads on the swap.  I was just hoping you were not a tooth off either way.
now you get to take apart the old one and get the pickup out.  save it for a spare as well as the TFI.
Changing my Dizzys
Lets say I was one tooth off, how bad and whats the fix? It feels different but not really good or bad. I marked it with sharpie, noted where the rotor was, removed, lined up, dropped in then started and gustimaed my timing. Start fine, timing is off but other then that it *seens* ok. Still, it's night and day difference in how it runs.
Changing my Dizzys
Quote from: jcassity;122622
plug and play,,
Couldn't you make up for being off a tooth by rotating the distributor a bit once its installed?
Changing my Dizzys
No clue my good man. Scott....?
