Poll
What color should my gauges light up?
Total Members Voted: 6
Topic: Looking at some of panther37's gauge faces but torn on the color! (Read 1658 times) previous topic - next topic
I've talked to Panther37 about having him make me some indiglo gauge faces (like the has listed in the vendor section). Since I have Automter Phantom gauges in the car, I'm gonna have him make these faces look like Phantoms. However, I can't decide what color I want. Right now I either want white face that light up green (like the Autometer Lunar gauges) or white that light up blue (like the C2 gauges). Which should I get? I currently have reverse indiglos that are blue, and admittedly the blue has kind of a glare to it sometimes (I always figured there had to be a reason so many factory cars used green lighting in the instrument cluster). I like how the blue looks, but most of the other stuff in the center console still lights up green. Opinions?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
well what do you have in the car already for the color gages? if nothing but stock then id go with something that would compliment your interior.
Got that fox rash again!
-Resident smartass! :ies:
I said I have reverse indiglos...which mostly light up blue (aside from some red marks on the gauges), and I have blue bulbs in my autometer gauges. I'm planning on switching to LED's on all the small gauges, so I could go green or blue there.
Garrett H.
Exhaust sound clip
Another clip
Red.
I preferr blue, but the green is also good...when i get an buttstuffog cluster I will go blue for sure.
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
I voted blue just because you dont see much blue in guages,  I think it would look better blue
Can't do red...tried that once, unfortunately the orange needles on the gauges kinda disapper with red lighting.
Ok so a week or so ago I ordered a couple blue 194 LED's off ebay just to try them in my gauges and see how they look (because they were super cheap). Well, check this out:
I realize that isn't the best picture, but that's hawt! The gauge on the right, obviously, has the LED in it. It's brighter & bluer than the blue bulb on the left and makes the gauge look 10 times better.
Based on how shagy the gauges look with the blue LED's in them, I'm leaning in that direction myself now...
Garrett H.
Exhaust sound clip
Another clip
Quote from: Red_LX;122372
Paint your needles black.
I'd prefer to not take apart my gauges.
Garrett H.
Exhaust sound clip
Another clip
I like the Green.. I've had the same issues with blue gauges.
Blue. Now you just need to figure out how to change the remaining green instruments to blue and relay that info. :D
Define "instruments?"
I actually found last night, through a little fiddling around, if you stick a blue LED in the climate control unit, it will turn the lettering and numbers a much more bluish color. The odd thing though was that the "cold" part of the slide (where you select between cold and hot temp settings) was brighter than everything else when the LED was in there. :dunno: Haven't tried the system sentry.
Probably gonna pull the headlight switch off today and see if there's a chance I can switch that bulb out too.
Garrett H.
Exhaust sound clip
Another clip
