Topic: Posi or Locked? (Read 4905 times) previous topic - next topic
Posi or Locked?
What do you guys think about Differential?  :)
Posi? (Clutch)  or Locked? (i mean always locked).  :2c:
Re: Posi or Locked?
I think every car should have one. They're pretty.  :p
Posi only locks up when it's needed, and lets the wheels turn at different speeds when needed (driving around corners).
Locked (always locked) sounds like a "spool", where the rear end is basically one solid shaft. Great for straight-line driving at the track, but  for the street. Turn a corner, and either the tires scrub themselves to death, or they'll be hopping, jumping and chirping around the corner as the back of the car does a little dance. There's the chance of an axle breaking too, if you have real good traction while going around the corner.
Re: Posi or Locked?
my friend has an air locker in the rear of his wrangler. when its on its like a spool. on the tar the jeep will actually push the front wheels str8 if he turns them pulling from a dead stop. spools are for the street only.
~John~
Re: Posi or Locked?
Ummm... is that your final answer?  :rolleyes:
Re: Posi or Locked?
I think he mighta meant spools are for the strip only... at least I hope.  Maybe his town doesn't have any interstections.
Re: Posi or Locked?
sorry, meant strip. 1 year olds can do that to ya
~John~
Re: Posi or Locked?
I put a richmond locker in the Demon las month.  great traction and launch when you launch it correctly... I have to powerbrake her to 1500 or more now to get the launch to be smooth on full acceleration.  If I just mash the gas grom a stop without the powerbrake I get horrendous wheelhop.  No noticeable difference on a light throttle acceleration from a stop.  It opens up on turns and there is an audible clicking noise.
