Topic: Post up pics of your wheels.... (Read 267455 times) previous topic - next topic
Reply #255
I had a real set of 93 cobras on my old bird(86) but dont have any pics, that was in 94
Quote from: ProTouring442;313148
Anyone ever put a set of '93 Cobra replicas on a 'Bird?
http://www.latemodelrestoration.com/item/LRS-1007RSR
Shiny Side Up!
Bill
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
Reply #256
Quote from: 1979 Cougar XR7;288681
heres a set i ought for my cougar awile back  and when i got em home they wouldnt fit my  front calipers were too big
Those are my old wheels; do you still have those?
Matt
Here are my rims
Reply #257
14 inch unique chrome rims 4 bolt. there on my 1988 ford thunderbird sport 5.0
Reply #258
Quote from: kilby109;377593
Wow....Nice
Reply #259
Thanks, this is a reply to an email i got about my rims. They are 14 inch unqiue chrome rims.  They were the only rim that i could find that would fit my car. They are 4 bolt rims and the only thing is they stick out a half inch at the front because there is no off set.  I think my tire size is 225r14 but i'm not exactly sure because it is stored right now for the winter and i am currently in school. i would suggest sticking with the original size tire because if i hit a big bump the tire rubs at the front on something so when its time to get new tires i'm going to switch back to the original size tires. also i'm not exactly sure the width of therims maybe 7 inch but thats a guess.
Reply #260
15" American Racing
Suits the car perfect in my opinion
Reply #261
Quote from: kilby109;400073
Just a fyi, any 4 lug Mustang wheel will fit your Tbird. Some tire stores will say they don't because Tbirds are different.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #262
these are centerline warriors, with old little tires
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #263
Will always love your car Thunder!!
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #264
aww shucks
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #265
Roflmfao!!
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Reply #266
I think most of you will disagree with the stretched tire tuck look, here's mine though
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
Reply #267
Quote from: 23027;400704
It doesn't look bad.  The tires just appear to be a tad too narrow for the wheels.  Was this done for the look, to allow for clearance or due to financial constraints?  How is the fender lip to wheel/tire clearance? What is the size, width, offset and backspacing?
Reply #268
I was going for a stretched/hellaflush look. The wheels are 18x9's all around, +18mm offset. I think the tires are 225/45/18. I got all 4 as a package deal so I used them on the rears, with a 1.5" spacer to fill that large empty fender.. I will at some point in the future do it properly and have a correct wheel offset with a bigger rear tire. I always felt 17's were a tad too small for a car this big.. The clearance on the rears is within millimeters. I tried looking around to have my wheel spacers shimmed narrower by a quarter of an inch but no one would do them.
Reply #269
chrome 1993 Cobra replica's 17x8.5 on 245/45/17 Falken Ziex tires.
