Topic: Those stupid little "nipples" on the headlights... (Read 2694 times) previous topic - next topic
Somebody once told me those are for some type of headlight alignment machine, it attaches to those little "nubs" and helps align your headlights properly. I personally have never seen one of these supposed devices.
Anyway, it wouldn't make any difference if I cut those stupid things off would it? I wouldn't think it would matter but who knows if some place might fail you at inspection time for it :dunno: (the reason I want to cut them off is because I'm tryin to clean up my lenses and working around those things is a real pain in the ass)
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Normally I'd never say anything bad about nipples but cut them off, theyre used at the factory I believe and probabally never since.
Scott
I just sanded my nipples off,then polished the smooth area left behind....................Then I removed the "nipples" on my headlights.LOL.
They're actually a DOT requirement for aiming (even the old glass bulbs in the four-eye cars had 'em). I've never seen 'em actually used for that purpose though...
I did this on my '96. They really get in the way when polishing, so I just used the Dremel and removed them.
No problems, yet!
As a matter of fact, I don't know if they even adjust the headlights anymore in WV.
I like my nipples where they are, thank you very much.
All three of them. :D
Yeah I've NEVER had my headlights checked (except for proper operation) at inspection time so I figure it won't make a difference if they're gone.
Garrett H.
Exhaust sound clip
Another clip
imagine failing your inspection cause you were "missing nipples"
I thought those were just casting marks. Guess I was wrong. Either way, grinding them and the ford writing down makes them easy to clean and polish/wax
1988 Thunderbird Sport
The only time I have ever seen them used was when I took my F-150 to the dealer to have the headlights adjusted. They attached a machine to them, made sure the truck and the machine was level, and used the numbers on the face on the headlight to make everything line up where it was supposed to.
i hacked mine off for the light covers to sit closer. never a problem
Quote from: jcassity;122200
Heheh! all of My girlfriends fail his inspection if the nipples is missing, for sure, I like the beams with her nipples:hick: :evilgrin: :grinno:
Regards,
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
How do you explain that!
Quote from: Seek;122217
thats what i thought they were
