Topic: my engine update...opinions? (Read 963 times) previous topic - next topic
well not much has been done. Buddy has been building his engine dyno room!!! Which I'll probably use when my engine is done.
Engine info:
Formally a Explorer 5.0 with the GT40P heads.
will be bored out .030 over
rods reconditioned with larger ARP studs
ARP main cap bolts
Match port the heads
new pistons
*SIDE NOTE* He's having trouble separating the piston from rod, because of the skirt on the piston...any suggestions?
Edelbrock 600 cfm E-choke
Intake manifold...unknown SUGGESTIONS!!
[COLOR="Red"]Hydro. roller cam still but it'll be a Trick Flow Track Heat
INFO:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,000 RPM
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 286
Advertised Exhaust Duration: 294
Advertised Duration: 286 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.542 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.542 int./0.563 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: HR-236/359-2S1-10 [/COLOR]
make sure to check piston to valve clearance.  and make sure to buy the proper valve springs that match the cam.
and on the intake a weiand stealth or performer RPM.
Quote from: SLEEPER T-BIRD 87;121879
will do...those actually were my thoughts on intakes
That cam may be a little much unless you feel like spinning the motor to about 7,000 RPM for power.  It'll make power past the 6,000 RPM advertised......hell the Stage 1 will go to about 6,000, I've heard the stage 2 makes peak around 65-6600.
