Topic: Garret T3 (Read 1925 times) previous topic - next topic
Garret T3
I just put a T3 on my '87 Turbo Coupe...  It spools up to 6psi and then drops off to 0psi, almost like the computer is shutting it down...  Do I need a computer from an '83-'86 or is there another issue?
Garret T3
Sounds like another issue. Does the car stutter when the boost falls off and/or make any weird noises?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Garret T3
The car continues to pull all the way through the gear without stuttering or regaining boost, however whenever I lift (shift) it's like the turbo resets because then it spools up again.  If I accelerate slower I can get it to 8 or 9psi.
Garret T3
Weird. Sounds like there could be something wrong with your wastegate actuator.
Garrett H.
Exhaust sound clip
Another clip
Garret T3
I did rotate the compressor housing to use my top mount intercooler, but I kept the wastegate in the same place within an inch or less.
Garret T3
Quote from: Red_LX;121516
+1
The computer has nothing to do with it....
It's either the WGA or some other leak of some sort.
Garret T3
When the turbo was off, I noticed it was slightly difficult to pull the shaft out of the wastegate manually.  Should this be very easy?
Garret T3
No, it should be difficult to pull out. There might be a leak in the diaphragm in your actuator though.
Garrett H.
Exhaust sound clip
Another clip
Garret T3
here is the actuator that I'm running.  it fits perfectly and alows you to adjust it to whatever position you might need.  http://cgi.ebay.com/ebaymotors/T3-Turbo-Turbocharger-Wastegate-Actuator-Bracket_W0QQcmdZViewItemQQcategoryZ6755QQihZ007QQitemZ170065069423QQrdZ1QQsspagenameZWDVW
Garret T3
I do have a pretty good exhaust leak at the downpipe/turbo elbow... could this effect it at all, i.e. a lack of back pressure?
Garret T3
No, that won't change anything.  I'd check out the wastegate (make sure it's closed all the way).
Garret T3
Quote from: tc²;121996
We covered this before...no...no effect.
Fix the WGA adjustment.
Garret T3
Just ordered a spankin' new Turbonetics Wastegate... I'll let you guys know the result.
Garret T3
A lack of back pressure would help the turbo before it hurt it.
