Topic: GT and GTP heads (Read 4666 times) previous topic - next topic
GT and GTP heads
PowerPro crate engines say that the Explorer block came with "GT" and GTP castings on the block,,,, any thoughts since thier database is linked to FoMoCo?
How does this information interpert into what head?
http://www.rebuiltengines.net/lb_ford.htm
I know about the explorer having the gtp heads,, what about the possibility of them also having GT's?
It appears the 96 is the only effected model.,, and for a few months only,
perhaps their numbers are wrong, just look at how they classify the 1969 5.8 long block with respect (disrespect) to the heads by grouping it into early 70's years.
302/5.0
V8
96-10/96
P
Explorer, MFI, Non Roller Cam, Block #F1SE, Head #F1ZE-AA, Knock Sensor
in Block, firing order 13726548, GT cast next to #1 spark plug Ford Engine
DFX5
$2,573
$345
302/5.0
V8
12/96-99
P
Explorer, MFI, Non Roller Cam, Block #F1 SE, Head #F77E-AA, Knock Sensor in Block,
firing order 13726548, GTP cast next to #1 spark plug
DFX6
$1,695
$450
GT and GTP heads
hummmm,
take notice folks,, it appears even the pro's (well,, sort of) are just as confuzzeled???
perhaps there is a ford secret after all.  I gotta go back there and collect that cc data anyway.
http://forums.stangnet.com/showthread.php?t=517975
scott
GT and GTP heads
the none roller cam is wrong. didnt all ford 5.0's and 8's com wil hyd. roller cams from 85 on. the GT's came with whenever they started the 5.0's in the exploders till mid year 96-97 then the p. till the 4.6. something along those lines  and toss the fact that in the mix of all that they lost the egr ports
GT and GTP heads
Truck 5.0's had non roller cams up until '94......
http://www.foxtbirdcougarforums.com/showthread.php?t=10109&highlight=truck+5.0
Scott, that dude Tmoss knows his stuff.  He does intake porting. Here's his site:  http://www.tmossporting.com/
GT and GTP heads
Alright I now your good w/giving good info to whoever asks so I’m opening my book to give you my best info now remember the book could be wrong.
In 1996 ford stopped using the 5.0 in pass cars because of political emissions pressure. But the less scrutinized emissions test was still for trucks so ford let the pushrod motor live on in the SUV and w/the development of GT40 heads and them being superior over the E7 they continued the motor w/GT40 heads also because of less 5.0s being manufactured. Now a ¼ way though 97 ford engineers developed a better version of the GT40 and they called them GT40P theses heads were used on the 95 cobra-R models only not cobras. They state there old plan was theses GTP heads were to replace all 5.0 heads but that plan got sidetracked cause of the discontinuing of the 5.0 in mustangs & pass cars. So they used them in Explorer’s & Mountaineer’s.
Now some my already know that so on w/ the question
My book says a few different things
96-97 ¼ explorer heads 63.4-66.4
97 ¼ -later explorer heads 58.3-61.3
Now on a different page
Cobra and HO marine        F1ZE-AA 60.6-63.6
Cobra and HO marine        F3ZE-AA 60.6-63.6
GT40P 97 & later explorer F77E-AA  58.3-61.3
GT40 96-97 explorer          F1ZE-AA  63.4-66.4
GT40 all                              F3ZE-AA  63.4-66.4
As you can see the same casting # has different CCs. Now it also goes on to say in 93 the GT40 heads underwent a series of milling or slabbing as they put it in the cobra plant now they did not say how much (which I was upset about) now at my machine shop his book said that F3ZE (which is what mine were) is 62.1 and after doing my research and doubted all books had them CC-ed so my F3ZE already had .010 taking off When got the CC-ed he got 61.8-62 (some where in there) so for taking every .005-.006 off a head is about 1 CC you can see his book wasn’t so correct so I took another .010 off getting somewhere close to 60 CCs
and to my understanding all 5.0 in the 90s were hydra-roller
GT and GTP heads
Innes
i see you to are curious about the same thing i am.  Its funny how the quesitons i have are possibly not even questions at all,,, they  happen to be an "unawarness" of what ford engineers were doing during the year 1996.
Ill betcha there could be two ford exploders side by side dubed as 1996 but have two different head styles.
the same could also be possible for identical 1997 suv's side by side
is that  a fair statement?  i think it might be.
whatcha think?
nevertheless, this is so so interesting , including your discovery of "slabbing".  wonder what that meant anyway.  Did they add meat or take it away?,,.
wonder if tom , nick, shawn or carm could have any stuff on this matter.
GT and GTP heads
Quote from: Paul Flockhart;121478
im still looking at this site,, interesting how he cut the upper intake in half making it shorter and i guess more rounded.
GT and GTP heads
Quote from: jcassity;121565
Innes
whatcha think?
Sorry, I'm an electronics guy, not an engine guy. I can build an engine of course, but don't ask me trivia on 'em :shakeass:(back when I had my '88 Cougar I actually thought it had an HO, and even now I'd have to look up the firing order for my car - strange considering I've got the GM V8 firing order memorized from trade school). Having worked in GM dealerships and never having any trouble with any Ford V8's I've just never gotten deep enough into Ford engines to know a bunch about 'em. That will change with the 351 build-up though. And I do still have a scar on my thumb from my adventures with the Ford 3.8 (when it says in the shop manual to use something other than your hand to push pistons out, heed the warning. Casting flashes are SHARP)
I would agree with the engineering free-for-all though - for some things it seems Ford had no definitive answer, including the 88 Sport/8.8 rear controversy
GT and GTP heads
Yes id agree in 1996 though in both 96-97¼ GT40 heads it could be ether casting # F1ZE or F3ZE my book says F1ZE but clearly mine came of a 97 explorer and there F3ZE.
And the obvious if you go to a junk yard and ask for 97 explorer 5.0 heads they will tell you there 2 different ones.
Any way all this info I’m telling you I got from this book it’s very good and interesting but the more you learn the more you realize you don’t know and though a lot of people rave over this book I have learned of some discrepancies in the info.  http://www.bentleypublishers.com/gallery.htm?code=GFM5&galleryId=79
GT and GTP heads
Quote from: Innes;121729
I think what i was trying to say earlier is this...
I just wanna be able to recognize casting numbers and what parts are the better of the herd.  An example would be the 69' 351w heads.  To be able to separate that head from the "like" windsor heads means the difference between performance and oppss.
The Plans
Seems not only do my plans not go through, but Ford themselves can't seem to get ideas to stick. Even about the 85 cougar plant problems, and lost baggage at airports. I think I would pick up a 98' Explorer Heads. would they be the GT 40 heads?
GT and GTP heads
Quote from: 85CougarLS;121934
did i miss something?  whats that got to do with the price of fish?
you tell us,,, go read page one of this thread then let us know what you find at the bone yard.
GT and GTP heads
figured i didnt want to purchase something wrong. Hill of beans
