Topic: WTB - Swaybar attachment brackets and an '87 3.8L EEC (Read 3093 times) previous topic - next topic
I replaced the swaybar endlinks on my '85 this weekend.
Old'n'busted
http://www.griffshp.com/belchja/pics/endlinks%20002_resize.jpg
http://www.griffshp.com/belchja/pics/endlinks%20003_resize.jpg
New Hotness
http://www.griffshp.com/belchja/pics/endlinks%20004_resize.jpg
http://www.griffshp.com/belchja/pics/endlinks%20006_resize.jpg
I noticed for the umpteenth time that my swaybar brackets are twisted up like a pretzel. So, I need another set.
Also, I need an EEC out of an '87 3.8L. Part number must be E73F-xxx
look at the mustangs around the same year, u might be able to get them at autozone or a parts store
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
ill look around i probly have a set or two
Quote from: hellsing73;121381
The swaybar attachment brackets aren't carried in part stores.
Still looking...
call a ford dealer by you and see if they have them
:birdsmily:
Quote from: hellsing73;122769
It is an obsolete part.
just look for mustaings in junkyeards for a set
:birdsmily:
What can they be off of? I'll make a run to a freind's parts can and see is I can snag a set from an 88 T/c if they will work.
Quote from: hellsing73;122812
I realize I can find a replacement at a junkyard...but I am lacking in time to go get one for the present. Also, after the 25th of Jan, I won't be able to wrench for 6+ weeks.
Quote from: 84 Fila;122822
I honestly don't know. I think that all of our cars use the same bracket. Anybody have a clue?
If you find out, just let me know
Mustang brackets are too short...you have to use T-Bird/Cougar brackets, probably Mark VII also. Believe it or not, I don't even have a spare pair...
I might... just MIGHT, have the set I took off the parts TC. Not sure if I kept 'em or tossed 'em when I installed the TC sway bar into my '88 (I re-used the 88's brackets). Lemme look tomorrow...
Fox mustang stuff will not work as stated.. however, sn-95's use the same dropped swaybar setup.
I can't find my old brackets, so I think I tossed 'em when I tossed the old struts, spindles, rotors, rack, etc...
Sorry J
