Topic: Help!! found a valve that is not pushin oil (Read 2686 times) previous topic - next topic
well i had a ticking and opened up both valves covers and let teh engine run. every valve was pushing oil on the passenger side so it was good and on teh drivers side the only valve that was not pushing up oil was #4 going from left to right. the rod doesnt look bent and there is spring action. a friend told me its clogged and that i could spray carb cleaner in the hole from were teh oil pushing out on the valve so i can un clog it. does anyone kno what else i can do. help is very appreciated. by the way happy new year!!!!
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Pull the rocker and the pushrod, see if you can see or blow through the pushrod then go from there.
Scott
spank that lifter for not doing its job
thanks scott ill do that
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
In 1985 I was purchased a Mercury Meteor with a 351C have the exact same problem on ONE valve, I slacked the rocker, putted out the pushrod, and checked, not blocked, and I don't wanted to disassemble the entire intake to remove the lifter...
I tryed a stuff for that at Canadian Tire, and after 2-3 Days and sped 3-4 rockers :dunce:  the problem was solved...
Generally if is not the pushrod blocked, it's a blocked lifter...
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
yea my lifter is blocked so i bought one that i gotta pik up tomorrw and hopefully this bs will all be over.. hey does anyone have the amount of lbs for how much the stuff has to be torqed back into place??
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
25ft/lbs max.
if you have regular rockers that were stock.
NOW I HAVE A QUESTION:grinno:
why only 1 lifter,,, why not just bite the bullet and get the  whole set?
I agree with JCASSITY, a whole set of lifters is not very very expensive, and this will refresh this part of Your engine...
This is the same if You change only a one faulty spark plug on You're engine :grinno:
i was gonan get teh whole set for 180 but den its a 5.0 so and i rather spend more $$ on anew engine .. liek i dunt plan on having this engine for a logn time in my car in teh future i plan on buying a more powerful motor with a much better tranny a  better rear end. i was thinking of  changing it but im like ehhh i dunno
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
my friend who is kinda old worked for chevy and he told me and suggested to buy only 1 for the amount of money .. i todl him wtas my best bet and he told me 1... i woulda bought teh whole set but i dunno .. well i still have time to buy it cuz i gotta go pik it up 2morrow.. well see wat happenes
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
in the words of jeremyb
"wiskey tango foxtrot"
i can get a rering kit for 200!!!
were these special lifters or sumthin? cause there aint no way id do that with a stock engine.
wait wat do you mean???  im not spending 180 on one lifter man.. i said if i were to buy the kit id pay 180 .. what do you mean im confused
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
o0h did you think i said 1 lifter for 180??  haha no way man he told me a compelet kit for 180  .. thats the reason why he said to buy one only,, so i would spend less man
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
no,, i thought that was the cost for 16 lifters,, im like holly .
this was the first time you said the maigic word,,,,"KIT".  Obviously that means all lifters and associated gaskets.  Big difference in automotive terminology,, sorry if i confussed you.
a set 16 stock lifters dont cost 180.
The kit probably will.
yeah yeah its the kit that he told me that would be 180 lol sorry i shoulda said that
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
