Topic: Front struts. (Read 1675 times) previous topic - next topic
Front struts.
Over the summer I switched to the TC 8.8. When I did this I went ahead and replaced the shocks, and added the quad shocks. I used KYB Gas-A-Just for all of them. So I decided to replace the front struts now, but Summit has had them on back order since June. I was looking at using the KYB GR-2. So I was doing a search on the internet and came across a guy selling Koni adjustables, part number KO-8741-1017 for $99.96 a piece. I tried doing a search on this part number and could find no information on this particular strut. The same guy is also selling KYB Select-A-Ride Gas Struts for $49.96 part number KY-734002 where you can select the level of firmness that you want by using a screwdriver on the top of the strut and selecting what you want. However a search of this part number also yielded no results. Has anyone ever heard of or seen these?
Front struts.
Never heard of those adjustable KYBs.
Are those differrent than the AGXs, or whatever those are?
Front struts.
Quote from: Chuck W;118888
The AGXs have a dial on the body of the tube that you turn to get the desired stiffness that you want. There are 8 different settings. The Select-A-Ride have a screw type mechanism in the very top of the strut that you adjust. There are only 4 settings. You have to open the hood to do this.
Front struts.
Never heard of those.  They might be worth a shot for the price, but $99 each for the Konis is pretty good though....
