Topic: What subframe connectors? How install? (Read 3224 times) previous topic - next topic
I want to put subframe connectors on my 85 Tbird.  I purchased subframe connectors that are said to be for a 86 - 93 mustang, with seat braces.  When I put them under the car to check for fitment, those braces don't line up with anything...are they supposed to on our birds?
I've read others have cut the braces off and just welded the straight bar?  Is that enough, or do I need some lateral support on the subframe connectors?
Thanks.
the fox body mustang subframe connectors will NOT work with the cougar/thunderbirds... i cant remember who makes them that will work with our cars...s omeone will pipe up im sure.
chuck doesnt make SFCs, he does occasionally make the braces. the bottom mount style SFC for birds/cougars are jus straight pieces of 1x1.5x.120 steel.
bob makes some. 40bob.com
1"x2"x.120" rect tubing is what I used.
I've got a question about the Tbird/Cougar SFC's.
Do they protrude through the floor all that much, and would they be noticeable with seats/carpet installed?
I've seen 5.8Fastcat's with them installed on his rotissirie, but not with interior stuff over them.
I'd like to have some on my car someday, and am curious as to how they look.
:sorry: to hijack..
Quote from: FordTruckFreeek;117299
:sorry: to hijack..
Well unless you're installing through-the-floor SFCs, there is nothing protruding through the floor. ; )
lol, yeah, i kinda worded that a bit silly :cool:
just wondered what it's look like carpeted up afterwards, if it was exceptionally noticeable.
I got the subframes off 40bob's site, they're actually made by a guy here in WV....but they're nice for $65, have caps on both ends, and reinforcing plates.
Welding them in just takes forever, and I went through 2 spools of wire on my welder doing mine.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Quote from: Red_LX;117308
Yeah.....I couldn't sell mine with seat braces and hardware for that price......thus I gave up on them.
Quote from: gumby;117291
...the bottom mount style SFC for birds/cougars are jus straight pieces of 1x1.5x.120 steel.
If that's the case, why couldn't I just cut/torch the seat braces off and weld the straight pieces on?
Given the notorious flex in these fox bodies, I'm surprised we don't have a sticky with all this info (instructions & pics) already.
Quote from: jgonza2;117323
What are you talking about?  Using Mustang SFCs?  Well for one, the Mustang ones aren't straight, they are usually kinked.  The kinks are not needed for the Tbirds.  Also, the extra length in the Tbird wb would require a bit more material.  I like to use at least 5' lengths myself for "std" bottom-mount SFCs.
maximum motorsports dont sell them for cougars or birds? i may be confused with caster camber plates but i thought they did.
The MM pieces are just straight with no seat braces.  KB used to make them and whoever has what's left of their inventory may still have them.
Aside from the KB ones, mine were the only Tbird/Cougar ones with the seat braces.
MM sells std. length SFCs for our cars. I haven't a clue why they don't add another foot of straight steel to make the full length. :confused:
IMO, if you are going to put SFCs on your vehicle...do it right and use full length SFCs (such as Chuck's [which are no longer available]).
